01-02-2005, 09:31 PM | #31 | ||
Number 5 is alive!
I know it was in jest mate
;) Thanks for the specs. Got specs for the ef/l cams?
Kerry Tickford wings are for Tickford cars! "Experimental Racer" #6 1994 Gunmetal XG XR6 1997-1999 [B][COLOR=Red] 1994 Le Mans Red ED 2008 MA XR5 Mondeo 2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced |
01-02-2005, 09:32 PM | #32 | ||
Last warning
EF 4.0;
Intake opens at 16 degrees BTDC at 0.045mm lobe lift Intake closes at 68 degrees ABDC at 0.085mm lobe lift Exhaust opens at 62 degrees BBDC at 0.053mm lobe lift Exhaust closes at 18 degrees ATDC at 0.085mm lobe lift EF 4.0HO; Intake opens at 14 degrees BTDC at 0.045mm lobe lift Intake closes at 70 degrees ABDC at 0.085mm lobe lift Exhaust opens at 58 degrees BBDC at 0.053mm lobe lift Exhaust closes at 22 degrees ATDC at 0.085mm lobe lift
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
01-02-2005, 09:38 PM | #33 | ||
Blue eyed 17sec bucket
with running the xr6 cam will you be changing the fuel pressure reg ??
01-02-2005, 09:38 PM | #34 | ||
Number 5 is alive!
That was quick john.
01-02-2005, 09:40 PM | #35 | |||
01-02-2005, 09:40 PM | #36 | |||
Number 5 is alive!
Ive run my XR with a stock 4lt fuel reg without any hassles.
01-02-2005, 11:14 PM | #37 | |||
Where do you get that stuff from Rob/John? I hope you guys aint typing it up after looking through Ford manuals lol.
Sundeep |
02-02-2005, 01:13 AM | #38 | |||
Shoot.
BTW, how's the "Hothouse"?! :
20V Turbo |
02-02-2005, 07:41 AM | #39 | |||
Last warning
02-02-2005, 12:52 PM | #40 | ||
I guessed that it was from the workshop manual.
The cam is a straight swap, the rocker gear is almost identical. The lifters are different, which is why I changed the rocker gear, cause my old lifters were stuffed. But there has been no problems with the car at all in the week or so since, it's running really well, and it's quiet now. |
02-02-2005, 05:29 PM | #41 | ||
lol yep, straight from the workship manual.
02-02-2005, 05:55 PM | #42 | |||
windsor user
reckon i mighta had a few too many and put the brakes back in upside down eh? |
04-02-2005, 10:03 AM | #43 | ||
hey i got a 94 DA 62 50 AB cam for $30 today,,is that a good one for the EA ?
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds: |
04-02-2005, 10:07 AM | #44 | ||||
04-02-2005, 10:10 AM | #45 | ||
can't afford that much,,and can't be bothered,,it's going in tomorrow so i'll see how it goes..
27-05-2005, 09:51 PM | #46 | ||
Hello guys im new. So if you fit the EF/EL cam do you need to fit the other EF bits like the lifters etc and the EF rocker cover? Can you just shove the EF cam in and close the old bits over the top? (I have a NZ built EB2 which runs well enough except for drinking fuel like its coca cola)
28-05-2005, 10:18 AM | #47 | ||
Yes, you can put an EF cam straight in without changing rocker gear.
28-05-2005, 11:39 AM | #48 | ||
Thank you Psycho. Does the cam aid fuel economy as well as torque? Just curious.
28-05-2005, 11:47 AM | #49 | ||
I don't remember noticing a difference, though it was almost a year ago I did it.
