30-09-2007, 12:26 AM | #1 | ||
hey guys
was wondering where people are tapping into for their pos and neg to power some guages in one of those console guage pods?? also is the ECU down under the passenger kick panel?? and are the pin numbers written anywhere on it so i know which wire im tapping into for the o2 sensor as i have an AF guage to wire up?? thanks
30-09-2007, 12:43 AM | #2 | ||
Yes and yes.
Proud member of the All Ford Club of QLD _____________________________________________ 98 AU FORTE-Congo Green C2R body kit, 2 1/2 cat back Exhaust, Red Diamond 2800rpm stall converter BA front brakes, BA air box with pod http://www.aufalcon.com.au/cgi-bin/i...act=item&i=326 |
30-09-2007, 08:50 AM | #3 | ||
where abouts is best to get power for the guages from??
any wires under there that will cause trouble if u tap into them??
30-09-2007, 09:55 PM | #4 | ||
Brenden all I can think of right now is taping into the brake wire. The wire from the fuse to the brake light switch only think of that one becaues it dosen't have power until the ignition on.
01-10-2007, 08:22 PM | #5 | ||
Sales Representative
Why not just drag some in from the radio? you have 12v+, Ign+, Earth- and healight dim+
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
01-10-2007, 08:23 PM | #6 | ||
but that means pulling out radio to find wires = spaggetti = death LOL
damn small compartment back there when you have a single din DVD player and a single din screen
01-10-2007, 08:34 PM | #7 | |||
01-10-2007, 08:35 PM | #8 | ||
The ECU pinouts are in the technical section somewhere - I'll see if I can find a link. As for power, you should only need to tap into the ECU wires (including earth), and a light for when the lights are on - you can get that from any of the lighting in the dash, or the auto surround, etc.
01-10-2007, 08:37 PM | #9 | ||
Oh Yeah!
I can take a photo of what ones I used on the ecu and to run the gauge tomorrow if you like. Just remember when autometer say use the 5amp fuse... use it unless you like smoking
Oh no! Duffman can't breath! Oh, yeah! |
01-10-2007, 08:38 PM | #10 | ||
thanks for that JC
i wonder if the trans temp guage can use the inputs that the ECU uses.. otherwise i need to pick up a T piece to attach the sender it into my cooler line
01-10-2007, 08:39 PM | #11 | ||
i actually dont have any instructions to look at but ive had a squiz at the autometer site for what goes where etc
a pic would be handy tho duffman! cheers
01-10-2007, 08:42 PM | #12 | ||
ECU wiring is here:
http://www.fordforums.com.au/vbporta...article&id=168 It has the ECU pinouts for both the 6 & the V8. O2 sensor wire for the 6 is #35 for the live side, and #4 for earth. O2 sensor wires for the V8 are #35 & #4 for sensor 1, and #61 (power) & #23 (earth) for sensor 2.
01-10-2007, 08:44 PM | #13 | ||
Pin #37 is the auto trans temp sensor input - you could use that to go to a temp gauge.
01-10-2007, 08:46 PM | #14 | ||
so which side should i need to tap into??
i was looking at the ecu pinout guide in my max ellery manual and didnt understand what the 2 different pins were for
01-10-2007, 08:46 PM | #15 | ||
Pin #98 is the output for the intake manifold runner control - you could hook it up to a light so you know when the BBM switch has flicked over to shorten the runners.
There's so much you can do when you know the right pinouts!!
01-10-2007, 08:47 PM | #16 | ||
do we know if that is the same as the autometer sender?? of if its a different type of sender ??
01-10-2007, 08:50 PM | #17 | |||
In fact, for my V8, I actually wired up a on-off-on switch so I could monitor each bank of cylinders separately. So I had pin 35 to one input side of the switch, pin 61 to the other input side of the switch, and the middle switch pin then went to the gauge. You won't need this for an I6, but you could use a switch if you just wanted to turn the gauge off (it gets annoying sometimes having the whole thing moving constantly - good for the first week or so, but then the novelty wears off a bit).
01-10-2007, 08:53 PM | #18 | |||
01-10-2007, 09:00 PM | #19 | ||
i would be going to enzed and get what ever they give me to make it attach safely
the o2 guage has 3 wires the trans temp has pos and neg for the light and 3 male spade terminals for the sensor readout 1 pin is I (guessing ignition) 2 pin is G (guessing ground?) 3 pin is S (guessing sender?)
01-10-2007, 09:22 PM | #20 | |||
03-10-2007, 07:00 AM | #21 | ||
Walking with God
JC's helpful advice in full swing!
GK
