Old 03-10-2007, 05:58 PM   #1
poolkeeper
Its Resonating!
poolkeeper's Avatar
Default Trans cooler
Whos got one? which one?
Im thinking of running 2, anybody tried this?, I suppose I will need additional parts to connect the two coolers together?
thanks guys...
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2007, 07:05 PM   #2
mik
mik's Avatar
i have one ,dragged a van to noosa and around brizzy at xmas time no problem`s but you could run probably run 2 if you wanted, the 1 i used was a derale large size this one looks the same ......... http://cgi.ebay.com.au/DERALE-auto-t...ayphotohosting
Old 03-10-2007, 07:48 PM   #3
private9
www.TUFFCARPARTS.com
private9's Avatar
I used a PWR heavy duty one - around $100 or so for the full kit from memory. Fairly easy to fit up yourself too.
I too am considering adding a second one (I've got an identical second one sitting waiting) but I just can't see a neat or easy way of plumbing it all up.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2007, 07:56 PM   #4
poolkeeper
Its Resonating!
poolkeeper's Avatar
I was thinking having the 2 coolers slightly angled on both sides of the radiator, so its fires the air into the radiator (sort of)
Or I could go for the fully out the bottom of the front bar look lol.
Old 03-10-2007, 09:20 PM   #5
ronwest
All Bran = Regular Member
I had one fitted just prior to our Tassie trip in June.
I think it's a PWR but don't have a model number to share. In size it takes up about half the frontal area of the radiator.
Cost $200 supply and fit.
Old 04-10-2007, 08:44 AM   #6
whiskers
gone fishing
whiskers's Avatar
I've got one on mine been there since new, fitted when the tow bar was fitted, (2600kg haymen reece)it was recommended to me when I bought the car. I don't know what the brand is. I used to tow a 26' boat to the local ramp and the car was never over heated.
Old 04-10-2007, 04:15 PM   #7
Mechan1k
Mechan1k's Avatar
I have a PWR Heavy duty V8 trans cooler on the work ute ... it copes very well with the abuse I give it.
Although ... if you want a decent one ... there's a B&M trans cooler with it's own thermostat on it (when it is cold it bypasses the cooler and allows the fluid to warm up quicker) .... it also has it's own front-mounted thermo fan on it as well for when it gets hotter (I am guessing traffic situations when towing heavy loads ... courier work ... etc).
It is a bit on the pricey side though ... but well worth it.
But FWIW ... the amount of heavy load work I give the ute in Sydney ... the PWR cooler works perfectly well and keeps trans temps down in the warmer weather ... especially when towing.
Old 04-10-2007, 04:46 PM   #8
poolkeeper
Its Resonating!
poolkeeper's Avatar
Where do I find the PWR ones? Think Ill just get what Mechan1k has.
Old 04-10-2007, 05:16 PM   #9
Mechan1k
Mechan1k's Avatar
I am pretty sure Repco and the like stock them.
Although ... if you can ... get a LPD cooler ... Low Pressure Drop.
I found the PWR trans cooler slightly affected shift performance as the pressure dropped slightly.
