29-05-2005, 04:16 PM | #1 | ||
likes falcon's
have complete motor, thinking of putting into an xf
besides radiator and thermo's wat else needs to be done, car is running gas research so ecu and injection system not required
www.carhubsales.com.au |
29-05-2005, 04:24 PM | #2 | ||
windsor user
possibly this shud be in X series forum???
you'll need XG engine mounts to start with. what gearbox is in it? if auto get the bellhousing off an EA 3 speed. |
29-05-2005, 04:25 PM | #3 | ||
likes falcon's
nah has xg t5 in it and an eb 3.45:1 lsd
and its ef motor :P
29-05-2005, 04:25 PM | #4 | ||
windsor user
ah ok
you can possibly run the EF BBM, you'd need to work out somethnig to switch the runners.... doing this may enable him to keep his current gas mixer..... mounts very similar to the XF EFI one Last edited by LUXO_8; 29-05-2005 at 04:28 PM. |
29-05-2005, 05:12 PM | #5 | ||
Custom user title
u will need to modifie an Xe dissy, pretty sure all u do is use the gear of the ohc motor on the Xe dissy, and re-drill the hole for the role pin.
29-05-2005, 05:45 PM | #6 | ||
likes falcon's
hmm cool, he's already using an xe one to run the gas
