11-05-2005, 12:40 AM | #1 | ||
Low and Loud
Hey all,
Yes again there is a EA issue (SHould have a separate "MY SCREWY EA PROBS" section for us ea ownerd ;) lol) Ive noticed over the last 4 days that in the morning when i go to start my EA, it coughs, splutters idles VERY ROUGH and stinks of fuel, I have to hold the revs @ 2000rpm for about 10sec or so for it to clear itself out or it simply goes to stall... any thoughts? Ive also noticed that the average has gone up to 17.0 from 14.2 :yeees: Nothing has been changed or swapped over on the motor.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : Last edited by InitialD; 11-05-2005 at 12:52 AM. |
11-05-2005, 12:47 AM | #2 | ||
BF F6, APV SR3900
stupid question.. how long since the oil has been dropped?
cheers, santo
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
11-05-2005, 12:49 AM | #3 | ||
Low and Loud
Wha? you mean how long since ive done a oil change santo? I did a oil change on it about 2000ks ago or so i think? just after the motor had done its first 1000ks
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
11-05-2005, 01:39 AM | #4 | ||
XR6 and XR8 Club of QLD
Check all of the obvious things
- spark plugs / leads - did the problem start just after you refueled (dodgy batch of fuel) - any hoses come off under the bonnet Sounds pretty tricky, but things like this usually end up being a simple little fault. Panda
Car - Ford Falcon XR6 Turbo |
11-05-2005, 06:01 AM | #5 | |||
Redhead extraordinaire...
It's gotta be some fuel issue, especially if you can smell it and your consumption is up.
Bloody EA's hey... just as I try to fix one thing on ours, another two things go wrong. The thing is, now the "problems" list is overtaking the "non-problems" list :( I'm moving to Melbourne :nutsycuck
Bindi 88 EA- his car 88 Rolla - MY car Quote:
11-05-2005, 08:40 AM | #6 | ||
And it runs ok after your initial start up? It'll be your TPS, no question - mines doing the exact same thing, I just haven't got around to fixing it.
Hot tip from my ex ford mechanic mate - elongate the holes for the screws, and twist the tps around a bit until it stops doing it. Problem being that the car is thinking the throttle is open more than it is and therefore throwing in excess fuel. |
11-05-2005, 11:41 AM | #7 | ||
Once shy... twice bitten
My TPS must be knackered too then, any idea how much one costs? Or should I just get one from the wreckers?
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11. |
11-05-2005, 12:29 PM | #8 | ||
Low and Loud
TPS eh? That actually would make sence!!!
Im having a problem atm when it goes to change gear, the auto hold gears occasionally. Right off to get another TPS and turf the old one
11-05-2005, 12:29 PM | #9 | ||
Two > One
Sounds like a cold start problem, linked with overfuling.
Im saying its a combination of screwed temp sender and ICS.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
11-05-2005, 12:31 PM | #10 | ||
likes falcon's
mine does it every now and then like once every few weeks, were it just runs like a reall dog, but doesnt stall
it doesnt happen often enough for me to worry bout it
www.carhubsales.com.au |
11-05-2005, 12:32 PM | #11 | ||
likes falcon's
oh and only ever happens wen its cold, so i drive easy as to not make matters worse and it goes away within a minute or so
11-05-2005, 01:08 PM | #12 | ||
Low and Loud
Could someone tell me if EL's had the same TPS as a EB?
11-05-2005, 01:48 PM | #13 | |||
Two > One
11-05-2005, 02:01 PM | #14 | ||
Former E-Series Member
I think you can use even an AU one if you want. That's what I'd do.
11-05-2005, 02:09 PM | #15 | ||
you'd need the dual type mick. the el will be a single one. your saying the auto playing up too would be weird if both your tps are bung one for eec one for tranny.
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
11-05-2005, 02:47 PM | #16 | |||
Low and Loud
Got another 2 TPS's to try out so see what happens
11-05-2005, 03:10 PM | #17 | ||
How much for the TPS ?
11-05-2005, 03:11 PM | #18 | ||
PM me if you want
You can run just a single TPS if you want, tap the wires together, I have a single TPS in my conversion to 4 speed auto, and am having no problems.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
11-05-2005, 05:29 PM | #19 | ||
Posts: n/a
you will find your injectors are leaking overnight and it is getting huge amounts of fuel on the valves and in the cylinders.
11-05-2005, 05:34 PM | #20 | ||
Low and Loud
Heres the update...
I took the Throttle body off, cleaned it out, put another TPS on and checked the ISC. Put it all back on, and its still doing it. When you go to start it, its rough as guts, like its missing, then clears itself after you rev it a couple of times. The other interesting thing is I switched the Trip Computer to INSTANT FUEL USAGE and when i take off normally to 60kph, and doing around 2000rpm, the instant shows 99??? None of my mates cars do this, nor does my mums EA ghia. This sounds like my injectors are flogged right? BTW curtis, sounds about right
11-05-2005, 06:09 PM | #21 | ||
so your running an ea computer and only 1 tps mick? have you done what jase has done?
ps your trip computer won't show the fuel going in if your injectors are stuffed. it will only show what the computer is thinking it is injecting. if its showing 99 somethings not right. usually they will show 99 if your at wide open throttle at that speed. you could get it to show 99 at 2000rpm but you'd need to have an iron foot™
11-05-2005, 10:09 PM | #22 | ||
Low and Loud
Yep karl, ive done the same as Jase did.....
LOL it shows 99 when i take off no matter how slow or quick Also... Whats a set of Reco Injectors worth anyway?
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : Last edited by InitialD; 11-05-2005 at 10:56 PM. |
11-05-2005, 11:27 PM | #23 | ||
01 Falcon Ute
i had a similar problem, i was told by a mechanic reco injectors cost 180, and brand new injectors are worth $220...
AUII FALCON UTE 2001 WTD mags to suit AU Falcon ute, AU XR rims or BA 18" xr rims. PM ME |
11-05-2005, 11:40 PM | #24 | ||
Injectors would be the G-O. I was thinking exactly what Curtis posted.
Sundeep |
12-05-2005, 07:58 PM | #25 | ||
Low and Loud
Just an Update...
I tried another set of injectors in the car and it appears to have Sorted itself now! BUT..... Im having a old problem crop up again. The car randomly goes to stall when your at the lights? like the ISC isnt working. Now ive tried many ISC's, TPS's, etc and have had no luck, Whats the chances its my ECU thats playing up? As its the only thing i havent swapped over
12-05-2005, 11:43 PM | #26 | ||
Damn, that means I gotta find some money for new injectors :(
Did it fix your fuel consumption reading on your trip computer?
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11. Last edited by ned; 12-05-2005 at 11:50 PM. |
13-05-2005, 02:28 AM | #27 | |||
undefined
31-05-2005, 07:29 PM | #28 | |||
Posts: n/a
31-05-2005, 09:32 PM | #29 | ||
Yeah mate, check the fuel pump relay and the ecu relay underneath the coolant tank behind the battery. Look directly under the 4 relays. Headlamps, starter etc. Fuel pump is green cover and the ECU is the other one. Check for corrosion on the plugs.
Cheers Luke.
EL FAIRMONT Pacemaker 4499's Megaflow 2.5in Cat X-Force 2.5in Sports Exhaust Champion STEEL igntion leads K&N panel filter, EL GT Snorkel, modified airbox 16in Speedy Holotype-R mags on 225 tyres |
31-05-2005, 09:55 PM | #30 | ||
Low and Loud
Who this is a old thread...
The problem turned out to be dodgy injectors as one of them were leaking. But my Fuel relay was screwy aswell. My only issue now is its still like 16.5 average?? The only thing i havent changed is O2 sensor and spark plugs
