09-12-2007, 08:56 AM | #1 | ||
Power & Torque
Hi Guys
My AU3 XR6 leaks water into the drivers front. When sitting in the car driving water falls onto my ankle. (I have just had the airbag/seatbelt pretensioner sorted by the local Ford dealer after the light came on the dash. I spoke to the mechanic who said there was water coming into the A pillar that had corroded the connections.) There is an obvious water problem as my carpet is slightly damp. I suspect it will be the windscreen. Does anyone have any ideas? |
09-12-2007, 09:01 AM | #2 | ||
There is another thread on a similar problem here, my thoughts are posted in there:
http://www.fordforums.com.au/showthread.php?t=11200959
I reserve the right to arm bears
09-12-2007, 10:03 AM | #3 | |||
BA GT-P Owner
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
09-12-2007, 11:38 AM | #4 | ||
when does it leak water?... when the air con is on?.. does the air con work well?
09-12-2007, 11:48 AM | #5 | |||
or silicon!
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track. 86 ZL mint grandpa spec with premo sound and 150000km 07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4! 97 el futura MOCKed up with a 2500 stall, heaps of fun! |
10-12-2007, 10:33 PM | #6 | |||
GT-P #0336
RspecAU
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST ~Tuned By Bluepower Racing~ |
11-12-2007, 02:53 PM | #7 | ||
Power & Torque
Hi all
I appreciate all the advice. I am getting my panel beater to have a look this week, possibly will reseal the front windscreen if needed. If no luck I'll look at what you guys have suggested, probably over the Christmas break. Thanks again |
11-12-2007, 03:01 PM | #8 | |||
Stops the water leak which is the issue here. |
11-12-2007, 04:08 PM | #9 | |||
BA GT-P Owner
14-12-2007, 08:58 AM | #10 | ||
Power & Torque
Hi Guys
Well I picked up my car from my panel beater yesterday. (NOTE: He said to find the source of the water leak, DO NOT USE A HOSE. To isloate the location of a water leak he said use a watering can. Have a person looking under the dash while you pour water. Start low, ie. plenum chamber, then work up the side of the windscreen very, very slowly. When it starts to leak, this is the level (area) where water enters your car). Anyway: My windscreen & seal were OK. A grommet in the firewall was not fitted properly due to someone previously stuffing around. He siliconed this. This was not the cause of my leak. The cause of my leak was the plenum chamber. He explained to me the plenum chamber sits under the wiper assembly catching all the water from the windscreen (like a gutter on a roof). The brake & clutch bracket are spot welded to the underside of the plenum chamber. 3 out of the 4 spot welds are broken. He has siliconed this to stop the leak. As it is a structural problem it needs to be welded. Fortunately my car is just in warranty and the dealer I purchased my car from has OK they will fix (?MIG weld) this under warranty. They have acknowledged this is a know problem with AU Falcons. This should then be a long term fix. Again thanks for your input, you guys were right. |
14-12-2007, 10:33 AM | #11 | ||
Power & Torque
I forgot to mention, again you guys are right.
Apparently this only occurs with MANUALS. This must be with repetitive clutch use the brake & clutch bracket eventually breaking the spot welds on the plenum chamber +/- firewall. As my panel beater said poor engineering & design (bean counters no doubt). |
14-12-2007, 10:30 PM | #12 | ||
Young !@#$ Head
I have the same problem in my Auto XR8. Maybe the extra torque of the V8 cause's it as well???
www.aufalcon.com.au/blackauxr8 AU3 220 XR8 CUSTOM PEARL PAINT LOWERED THEN LOWERED EVEN MORE ADVANTI 20's K&N PORTED MANIFOLDS TWIN 2 1/2 into 3 inch PIPES 244rwhp NOW WITH T5 5 SPEED COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL SUZUKI GSX-R 750 BLACK 2007 MODEL CARBON FIBRE YOSHI PIPE |
