Old 08-06-2005, 04:15 PM   #1
xr8ute
Back on the road
xr8ute's Avatar
Default Getting RPM Signal - AU V8
Has anyone installed a Tacho or similar, that can tell me what wire they used for the RPM signal?
I am installing my TechEdge 2BO tongiht, and want to hookup the RPM signal for some datalogging.
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2005, 04:26 PM   #2
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
Got a workshop manual? I would have thought IDM from EDIS would be the tacho source...
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2005, 05:00 PM   #3
xr8ute
Back on the road
xr8ute's Avatar
Yeah, just being a slack-**** at work :p
Umm...whats IDM stand for?
Old 08-06-2005, 05:04 PM   #4
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
you can take it from coil cant you?
there should be a diagnostics plug under the bonnet which you can take it from also..
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2005, 05:08 PM   #5
4.9 EF Futura
Err.... IIRC idm is ignition diagnostics monitor IIRC... basically a flyback signal from coilpacks...
Old 08-06-2005, 05:25 PM   #6
xr8ute
Back on the road
xr8ute's Avatar
Aaahhh, that sounds exactly like what I am after...LOL
Cheers, I'll give it a go tonight.
Old 08-06-2005, 05:33 PM   #7
santoitaliano
BF F6, APV SR3900
if you get a service manual it makes anything you wanna do so much easier..
you can also get it from behind the cluster, look on fordmods and see if they have cluster wiring information..
otherwise i wired mine to diagnostics plug, which at the end of the day is the same shit..
apparently wiring it to ground will also give you signal!!
bohh! so many ways.. pick one..
cheers
Santo
Daily:
Bluepower enhanced.
Old 08-06-2005, 05:59 PM   #8
xr8ute
Back on the road
xr8ute's Avatar
I've got the Factory AU Service Manuals so should be cool.
Is the diag port an E-series thing? With AU being OBDII, I would probably need an OBDII scanner to go that way.
Getting a "clean" signal will be the hard part I suppose.
Old 08-06-2005, 06:01 PM   #9
4.9 EF Futura
Yeah, diag port an e-series thing... good place to source a tach signal as well.
