Old 17-01-2008, 12:08 AM   #1
fourl6
AU Falcon Man
fourl6's Avatar
Default use standard remote to auto windows down.... (AU2 to BF)
the great hot weather around at the moment gave me an idea... could we instead of using that annoying 2 lock system (first press unlock drivers door second unlocks all doors... make the first press unlock all doors and second automatically put down two front windows... (id imaging with press one wire A gets a 12V pulse with Press two wire B gets a 12V pulse)
Stage One...
the two stage door open is set bye remote so we would need to modify the first press to lock all doors but still have the remote set to the "two Stage Function) - im hopeing this would be as easy as swaping one wire...
Stage Two...
Set the second Press to auto down two front windows...
i - first we would need to make the front passenger window Auto Wind down like the drivers (could be fairly easy as is hopefully more mechanical and hopefully not ran buy the B.E.M. which would enable us two swap some parts between doors
ii - link wire B to the window switch (down)
so at the end this is how it should work...
Remote set on two stage locking:
- Press unlock once all doors unlock
- Press unlock second time selected windows down
Remote set on one stage locking:
- Press unlock second time nothing (indicators flash)
Problems...
- that pain in the they call smart shield
- i have a strange feeling that the auto down for the drivers window wont be easy to copy for the passenger window
next step would be to setup a auto up with an override button in the car to leave car looked with windows cracked... but we'll leave that for now....
2015 SZ MkII Ford Territory TS
Aero Blue, RWD Petrol, Standard Sat Nav.
2013 TF Ford Kuga Ambiente
Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol.
Was
2012 FG Mk2 Ford Falcon XR6
Swift Green,6 Speed Auto, Stock...
2001 AUIII Ford Falcon Forte
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
1994 EF Ford Fairmont
Gun Metal Grey, Lumpy Straight 6
fourl6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2008, 01:11 AM   #2
JC
JC's Avatar
Great idea, but the auto down function is controlled by the drivers side button, not the BEM. Plus there is more than one wire to the window switches - if only one of these activates the window up/down, then the remote idea might work. But if more than one wire is needed, I don't think it could work easily. You might want to check out the Technical resources section up the top - it should have the wiring diagrams for the power windows etc.
Ford Performance Club ACT
Old 17-01-2008, 01:27 AM   #3
JC
JC's Avatar
The technical wiring is actually a sticky in the AU section. Here's the power window circuit. you may be in luck (at least for the down function):
http://www.fordforums.com.au/photos/...cat=676&page=1
For the auto up, you could use a relay with a power timer in it to get power when the doors are locked, but then keep power going until window is shut (say 5 seconds?).
Old 17-01-2008, 10:14 AM   #4
MRJUCY
Fordless
MRJUCY's Avatar
I don't know about opening but there is a kit that is/was floating around ebay for auto window closing but a few people weren't that impressed with it, I think Stav was looking into coming up with something better but I'm not sure how far along he got with it.
MRJUCY is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2008, 10:39 AM   #5
Mechan1k
Mechan1k's Avatar
Then there's the issue of eventually getting slow wind up times due to out of aligned window slides ... or sticky rails ... then it will stop halfway up when the timer stops.
The AU power windows are buggers ... my driver's side works like a dream when it rains ... but when it is dry ... it's slow as anything. Even after lubricating the guides it is still slow.
Old 17-01-2008, 10:46 AM   #6
DJL351
XR & FPV Owner
DJL351's Avatar
Early BA's had this feature..... sort of.
When locking the car, the drivers window would 'auto' all the way down.
Ford bought out a piece of 'plastic', to better sheild the window switches from the door lock actuator.
D
2005 BF GT (6sp manual - Build #183)
2015 SZ MkII Territory Titanium
2016.75 LZ Focus Sport
probably the stupidist post on aff - congrats
Originally Posted by flappist
There was once a time when every young man in this country was familiar with firearms and many owned them privately along with a stock of ammo and some bush gear.
Now the best we can hope for is to unfriend them on facebook then SMS their commanders with !!!1!!!!!!11!1!! and then finally plank a tank.......
DJL351 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2008, 10:46 AM   #7
FGII-XR6
FGII-XR6's Avatar
have you used silicone spray? this is the right stuff for the window runners
Old 18-01-2008, 07:49 AM   #8
Mechan1k
Mechan1k's Avatar
Sure have ... I have even removed the door trims and tried to ree-align the window as well ... and sprayed the entire runners as well.
I think either the motor is tired (although works nicely when it rains ... go figure) ... or i need to find someone who can align it properly.
Old 18-01-2008, 08:33 AM   #9
HLC
Audi S3
my front two windows are exactly the same.
damn slow, and often stick going up. going down is easy.
the rears work like a dream. silicone spray made them worse.
according to chief, graphite powder is the go.
Old 18-01-2008, 08:34 AM   #10
Mechan1k
Mechan1k's Avatar
Will have to try that next time I guess and see how it goes.
I need to pull my door trims off again to secure my crossovers properly anyway.
Old 18-01-2008, 08:14 PM   #11
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Graphite powder is definitely the go . I used it on the rear passenger window of my NF as the window would struggle down then wouldn't rise more than 2"(5cm) when I bought the car but after a couple of puffs of graphite powder down both runners the window now runs like a dream up and down. The front was a bit slow too as it drops forward going up but a couple of puffs and it's good as gold.
Bushbasher
MINE- AUII Forte
Old 18-01-2008, 10:00 PM   #12
fourl6
AU Falcon Man
fourl6's Avatar
have been doing some B.E.M research using This pic...
so are these the output or input pins???
B3 - unlock switch - 0/1V (Pulse????) -
A18 - Central Door Lock Switch - 5V off, 0/1V on
C8 - is drivers Door Unlock - (does not give a voltage)
there is also Front Drivers Door Feedback B20... what does this tell the bem...?
and C6 central locking feed
but i did notice that the boot releace was a nice 12V-13.5V could use this instead... just wondering for ute and wagon people even though they dont have a boot button if you programed a sedan key to the car would there still be a boot release pin (C7) that would release 12V when pressed...?
Was
Old 18-01-2008, 11:30 PM   #13
fourl6
AU Falcon Man
fourl6's Avatar
This Could Also be of Help (BA Auto Wind Up When Doors Look)
Was
Old 19-01-2008, 12:50 AM   #14
chief
FTF Club Moderator
chief's Avatar
For sticky windows graphite powder is the best lubricant. Unlike silicon spray it does not attract dirt and have it stick to the windows. Plus you can use it in the door locks and ignition barrel.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2008, 01:16 AM   #15
waggaclint
waggaclint's Avatar
my wagon has a boot release button its opens the tailgate....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2008, 08:25 AM   #16
fourl6
AU Falcon Man
fourl6's Avatar
hmmm i thought theyd have a release in the tail gate that would work like a doorhandle ... i guess not..
Was
Old 19-01-2008, 08:29 AM   #17
Stav
Smile
Stav's Avatar
You need a trigger to do power window closing.The trigger to be done properly must be independant of central locking signal or blinker.As these are the only 2 sgnals out from the computer then a direct trigger may not be viable.I think I can do it though. Somehow.
