Old 04-03-2008, 09:28 PM   #1
au^dude
au^dude's Avatar
Default Headlight Globes
Hey i need new headlight globes. The ones i have in my car now are 60/55W. Can i get any other more powerful ones say like 100/90W?
I wanna make sure i wont stuff my headlights and they aren't illegal.
Thanks
au^dude is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2008, 09:33 PM   #2
UU TS50
T3 TS50 075
UU TS50's Avatar
There are special globes that you can get for the polycarbonate
lenses . Probably are illegal but if you have them adjusted right
you would probably be ok ?
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2008, 09:38 PM   #3
au^dude
au^dude's Avatar
Prob jus be safer to stay with the standard Watt ones. Better that then geting in trouble with the cops
Old 04-03-2008, 09:40 PM   #4
UU TS50
T3 TS50 075
UU TS50's Avatar
You can get brighter lights that are still the same wattage
i nearly bought some for an EF my missus had before
Cheers John
Old 04-03-2008, 09:53 PM   #5
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
go and look for Narva +50's .They are the same wattage as normal globes but 50% brighter. They come in most popular globe sizes. I have them in my AU wagon and they are much brighter than a standard globe.
Bushbasher
MINE- AUII Forte
Old 04-03-2008, 10:17 PM   #6
ayeyew
Teh Baest
ayeyew's Avatar
Thanks
One of my mates has had 110/100W globes for the past 6 months, says on the pack "for offroad use only" or something along those lines.
He has had no trouble from coppers, they dont look that much brighter on regular, but high beams.. omg.
But yeah, you can get brighter or higher intensity bulbs, even with the same power running through the filament, it's all to do with the surface area of the filament, efficiency and the temperature the filament runs at (Different bulbs have different spectral distributions with different temperatures)
So yeah, just because they are higher power output does not necessarily mean they will be brighter. It is not a linear relationship between the two.
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2008, 10:27 PM   #7
LUXO_8
windsor user
Thanks
you'll stuff your headlights, and probably the globe plugs.
they run hotter, so will tarnish the reflector, and probably even melt the lenses. i have seen the plastic shroud in the headlight cracked due to excessive heat from globes as well.
au's have mint headlights, i cant imagine anyone wanting brighter headlights for regular on road use.
Old 04-03-2008, 10:34 PM   #8
StealthAu
I reckon they are pretty crap compared to what I have had in other cars. In fact even cars 20 years older then my AU seemed to have better lights then the AU.
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2008, 11:09 PM   #9
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
i agree with Luxo_8. Get good quality standard wattage Tungsram bulbs, ensure you have clean polycarbonate and align em right (drive up to a wall (preferably a brick/block one on flat ground) and adjust them using the little orange turny knobs(tm)) and you'll find you've got the brightest lights on the road this side of xenons.
Old 04-03-2008, 11:14 PM   #10
blackers10
blackers10's Avatar
we got the phillips bulbs for debs car (were around $60 for the pair in a blue box from repco)
they are very white in appearance and are very bright!
being a fairlane its only single bulb for each light
so the low beams are much brighter due to the new bulbs but the high beams are still the old globes so cant comment there
Old 05-03-2008, 12:50 AM   #11
JC
JC's Avatar
Fit a HID Bixenon kit. You can get them on ebay for around $150 and they should last around 5 years at least. You will not get better light, and no problems with lenses or reflectors - they actually use less power than "standard" replacement globes (35W compared to min 55W)
Ford Performance Club ACT
Old 05-03-2008, 07:31 AM   #12
LUXO_8
windsor user
less power but draw more amps. shouldnt be a problem though, ive been running a HID retrofit for years in my NC (lexus ballasts, accord euro projectors) without any problems...
if you feel confidant about doing some custom work, a retrofit shts all over a kit, let me tell you
Old 05-03-2008, 07:46 AM   #13
StealthAu
Not possible. Less watts at same voltage means less amps drawn.
35watts at 12vdc = 2.916 amps
55watts at 12vdc = 4.583 amps
Old 05-03-2008, 11:49 AM   #14
au^dude
au^dude's Avatar
I'm getting these lights
Old 05-03-2008, 12:07 PM   #15
Mechan1k
Mechan1k's Avatar
The initial amp draw for the ballast to ignite the HID is massive though .. the ballast steps down wattage for the HID filament.
I used to have a kit in my AU headlights ... then in aftermarket headlights. They were good in a way .... but very bad in others
The standard headlight will not be able to control the beam properly causing glare for oncoming drivers ... you don't realise the stray bits of light until you drive up to a wall with them on.
If you can ... get HID projectors (different from halogen projectors) ... and the full retro kit out of a wrecked Euro car .... so many to choose from ... even retro kits can be bought off eBay from the US .... you need to the timer and patience ... and skill to modify the existing headlights.
I just went with halogen projectors inside my AU headlight (careof: The Dok) a few years back ... they have been great.
For headlight globes ... nothing beats the Narva +50 for "legal" halogen globes ... I have tried many and did side by side tests on country roads ... the +50 had much better distance.
Old 05-03-2008, 01:47 PM   #16
JC
JC's Avatar
Hmmm.... I thought Amps = Watts/Volts seeing that Watts = Volts * Amps)
So at a constant 12 V source, moving from a 55W globe to something that uses 35W, means Amps reduces, not increases.
***EDIT*** Oops - looks like others beat me to it!
Old 05-03-2008, 03:34 PM   #17
Chamelion
Could you please post up your results at some point? I'm trying to decide between those exact bulbs or forking out for some HID Xenons.
Matt.
Chamelion is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2008, 05:05 PM   #18
LUXO_8
windsor user
yeah thats what i meant, there's no filament in a HID capsule though, hence the massive voltage / amps on startup (the charge has to jump from probe to probe to ignite the gas, once its lit, it can settle to a low voltage to maintain it)
here is a good little vid to show the spike on startup
http://www.youtube.com/watch?v=NCqjSLUIkjk
