Old 17-03-2008, 02:47 PM   #1
75van
Van Mad
75van's Avatar
Default Clutch pedal sounds
I've tried searching for the answer to this odd question but nothing matched it quite right.....
When I let my clutch out a sound like a wire against a spring can be heard - sort of a 'sproing' sound like an old chest freezer spring (sorry, not good at impressions!). Going in the clutch doesn't make this sound, only on the outstroke. Have checked the spring at the top of the pedal, and there is nothing interfering with the spring, the cable is nice and new, and adjusted nicely.
Anyone have any ideas what's making the noise?? A few sets of lights in town and the noise soon gets on your nerves!!
The new wheels: 1975 Ford Escort panelvan. Build blog here.
75van is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2008, 03:37 PM   #2
aye you
The Origional, The Best
aye you's Avatar
mine does this too, i just turn the music up
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2008, 04:00 PM   #3
cobramania
FPV BFII GT Cobra No.249
cobramania's Avatar
I can't exactly say for an AU (I've never owned one), but from the EA up the pedal box cracks & the clutch pedal rubs against the pedal box, it also puts the clutch pedal out of allignment & the clutch inner cable rubs against the outside covering. This problem is well known in the EA-ED models, check around the pedal box where the shaft goes though the pedal arm. If it's cracked it will need to be taken out & repaired/replaced by a smash repairer, you'll also need to replace the cable as the cable wears where it grinds the inner & outer parts together.
The BA up don't seem to have this problem as the clutch is now hydraulic. With no cable pulling against it & no pressure from the clutch pressure plate there is less pressure put on the pedal box.
This may not be the problem, but if the clutch pedal is out of alignment the spring could be catching & moving in it's mounts as the pedal comes back out, making the sound you said.
cobramania is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2008, 08:20 AM   #4
75van
Van Mad
75van's Avatar
Nah, firewall isn't cracked, maybe the spring needs some lube on it?? Any special type of lube that is for springs?
Old 18-03-2008, 03:40 PM   #5
cobramania
cobramania's Avatar
I didn't say the firewall. The pedal box is totaly seperate from the firewall.
The pedal box sits against the firewall but the pedals connect to the pedal box.
If you think it's not cracked though try some lube on the spring, spray a bit of WD40 (or similar) & see if that works. If not try some Vasoline or grease.
Old 18-03-2008, 04:32 PM   #6
75van
Van Mad
75van's Avatar
Sorry I didn't pick that up before - I've been looking at so many posts about the firewall cracking that I was confused! : I'll have a look tonight and see if the pedal box is cracked anywhere...
Old 18-03-2008, 08:43 PM   #7
bf tubs
 bf tubs's Avatar
mine did it for a bit then went away ??
my brothers does it so it pretty common
 bf tubs is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2008, 08:48 PM   #8
LeadFoot81
_Oo===oO_
LeadFoot81's Avatar
Mine does it too, thered have to be something there you could lube to make it go away.
LeadFoot81 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2008, 10:16 AM   #9
75van
Van Mad
75van's Avatar
Found out exactly what is going on down there....
Where the spring goes through an eyelet on the firewall, there is no bushes or silione to stop the bare spring rubbing on the metal of the eyelet. The pedal end of the spring has a good plastic bush on it to stop rubbin gon the pedal. I put a bit of good ol' Vaseline over the firewall end, and three pumps of the pedal later and the squeak is gone! Vaseline has yet another use! :
Gonna try removing the spring and hooking some heatshrink over the problem end, or machine up a bush from some oil impregnated plastic when I get a chance, and see if I can find a long term solution.
