Old 12-04-2008, 08:22 AM   #1
mudwaa
Default SCT Xcalibrater2
Anyone know the ECU code for a 2007 LS. Thinking of buying the Xcal flasher from focussport, is just over $400 oz. Anyone help, thoughts or anyone who haschipped/flashed their LS.
mudwaa is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2008, 11:46 AM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Mudwaa, it will be different for different cars.
You're unlikely to be able to get an Xcal2 to suit from Focussport, as the US is unlikely to have the same ECU codes. You'll have more luck with Dreamscience in the UK.
The ECU code is normally printed on the ECU itself, so you'll need to locate that (I only know in LR's, not LS's, but some of the other guys will know)
Old 12-04-2008, 12:50 PM   #3
mudwaa
cheers melbzetec, dont know where the ecu is either yet, anyway i thought for the saving which is round $300 min against a capa one. could you not have the right settings added by someone in OZ?
Old 15-04-2008, 01:52 PM   #4
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
I think the ECU is above the engine, between the firewall and the engine.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2008, 05:21 PM   #5
motorex
so at end of day. Is there anyone/any thing over here to tune the focus
motorex is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2008, 08:45 AM   #6
photn
AFF Post NAZI
photn's Avatar
in sydney i would look at autotech, melbourne would be Rob Herrod and someone else would be capa.. not sure ware they are located.
