31-05-2008, 01:45 PM | #1 | ||
Stroking it...
This will sound like a stupid problem, and it is, Well i Need to do a compression test on my AU V8..
I have a spark plug remover tool "thingy" and several sockets, and i cant get the bloody plugs out! The tool is fairly thin walled but i cant even feel the err "thread" for the tool or my sockets to catch onto, i dont want to keep trying and risk having the plugs stuck in there..My old mechanic used to tell me my plugs were fine and didn't need changing, could they have been tightened too much that they are stuck?! Or is there some other sort of plug remover tool i need? wtf?!?! help appreciated ASAP before i set fire to this car! Helllllllllllllllp : |
31-05-2008, 01:50 PM | #2 | ||
Now Fordless
I havent done plugs on my 5.0l yet but have you got the right size socket? There are 2 sizes and I'm guessing these would use the larger one.
31-05-2008, 01:58 PM | #3 | ||
Stroking it...
Yeah i have the right size, i dont know if it makes any different but i have aftermarket heads..
Arrgghhh this is a stupid problem to have! Last edited by Cam; 31-05-2008 at 02:11 PM. |
31-05-2008, 02:02 PM | #4 | ||
Fiat POWAAH!
The plugs on mine were a nightmare to get off too, expect to squeeze and contort your hands into some tight spots to get them out.
31-05-2008, 02:10 PM | #5 | ||
Just use a 16mm sparkplug socket out of a half inch socket set with a 2,3 and 5inch extension and double check that your turning it a anti clock wise direction ,the 16mm sparkplug socket should have a rubber gromit in side it and is about 65 to 70 mm long
you,ll find that it will make a bit of a crack at the start meaning its just a little rust or carbon build up , A half inch set will on a 1/4 inch set good luck |
31-05-2008, 02:12 PM | #6 | ||
Stroking it...
wtf? i got told to use a 21mm, sdklflskfhslhflsfhlasfhasf
/end vent Off to try again.... |
31-05-2008, 02:13 PM | #7 | ||
sorry i ment
A 1/2 inch set will sh@t on a 1/4 inch set |
31-05-2008, 02:28 PM | #8 | ||
Stroking it...
thanks mate, got one off, so thats a start :P
31-05-2008, 10:17 PM | #9 | ||
lol i could have told u that cam.... :P
i won. |
01-06-2008, 12:23 AM | #10 | ||
Boost Addict
AFAIK the 302/347 have the small socket sparkplugs, the 6s have the large socket sparkies.
best way i found was using 3/8 set with 1" wobble extension (not universal joint) and breaker bar to crack the set, after that u can almost unscrew them by hand. with aftermarket alloy heads i recommend to use some graphite grease on the new spark plug threads so they wont seize in, in cast heads its not as much of an issue.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
