Old 09-07-2008, 05:09 PM   #1
Robe
Question LPG Staggers When Slowing
More often than not when we slow down at an intersection the motor begins to run rough. It staggers, loses responsiveness and sometimes stalls.
This only happens when I am on gas. With petrol there is no problems.
I can prevent this from happening when on gas by manualy down-shifting the automatic gear selector to "second" just before the revs drop too far.
This a dual fuel 1999 AU wagon that has done 250,000+ kms and exhibits no other problem behaviour. It starts fine and idles smoothly.
I keep the petrol tank dosed with injector cleaner and switch to petrol from time to time when at highway speeds.
Any suggestions?
Thanks
Rob Ewart
Bog standard silver BF Wagon, except for the Elvis doll , on gas.
Victorian Rock'n'Roll Dance Association
www.VRRDA.com.au
2015 Victorian Rock'n'Roll Dance State Championships
23 May 2015, Furlan Club, Thornbury
Robe is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2008, 05:22 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Try the LPG forums, there's a few LPG mechanics there.
(Or ask a mod to move this post there)
Old 09-07-2008, 08:11 PM   #3
bodes-sh
what system is on it? it seems like either the balance line isn't set up properly, or the idle on the converter isn't adjusted properly
Old 09-07-2008, 08:29 PM   #4
sly
Sly like a G6
sly's Avatar
^^^ Those first, then maybe vacuum leak somewhere? My '99 AU has had a couple of split / cracked vacuum hoses this year and a suspect brake booster diaphragm, all of which have made the LPG play up more than the petrol.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2008, 06:02 AM   #5
au2sw
Blown 5L coming
au2sw's Avatar
also after a backfire these problems will occur. check to make sure your airfilter is clean first and foremost. then check all air ducting thoroughly to ensure there are no splits or breakages...especially the rubber elbow, they always split there. if the balance pipe (hose that runs from the snorkle side of the airbox to the back of the converter) is connected, then you may want to get it to your local fitter to get it checked out more.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2008, 10:15 PM   #6
Mechan1k
Mechan1k's Avatar
I have found if this sort of issue has only just started ... check to make sure your air filter is clean/unblocked ... then make sure the balance line is free of kinks ... and doesn't have leaks.
