11-07-2008, 07:49 PM | #1 | ||
after having some driving issues with my AU i took it to get a wheel alignment, anyway im talking to the guy when bringing the car in and he says it'll probably need a camber/castor kit, i said nah its all fully adjustable, and so on, anyway i took him out and show'd him and he has never seen one like mine and this is a large bridgestone store in cambellfield, along with 2 previous other stores that have told me the same thing. Anyway he advised me that he didn't want to do it cause he isn't familure with it blah blah blah.
Now my setup has on the top wishbone 2 large alley key'd head bolts that undo and you can move the arm in and out to adjust it, and you do it back up when in the correct position, so the question is does anyone else have this sort on their AU? Or know who makes em?
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
11-07-2008, 07:51 PM | #2 | ||
sounds a little like the adjustment kit that pedders have for them.
Can't beat a Windsor for sound and low down torque. Liquid Silver Pursuit250 Custom gear and diff ratios ECU Exhaust Crow Comp. Valve springs Adjust. Rollers Cold air |
11-07-2008, 08:34 PM | #3 | ||
growing up is optional
The Pedders ones are shim adjusted. Sounds more like a Kmac kit.
11-07-2008, 10:23 PM | #4 | ||
Now Fordless
I had a KMac kit like this on my EA. Heaps better and easier than using shims.
11-07-2008, 11:05 PM | #5 | ||
yeah i've checked the k mac website and its similar but the bolts are different, nolathane makes one too but its more different again, i basically want to find out what it is and how it adjusts so that when i go to the next place for a wheel alignment i can just go "oh its easy you just do this".
