Old 29-09-2008, 05:40 PM   #1
brad`
The Monty
brad`'s Avatar
Default good price or not ? Radiator problem..
Ok so i noticed i was dripping coolant a week ago, only a drop here and a drop there, so i went over all the Tubes and tightend everything up and then.. a day later it got worse.. was driving to work and my coolant light came on so i put some coolant in on my way home from work (had spare in the boot for some bazzar reason) and now i drive to work and back and when i get home im back to having the coolant light on
i stoped off at my local Radiator specialest on my way home from work today
and he told me i had a hole in the top right (Passanger side) of my radiator
he said its a common problem in the origional Ford Radiators, and quoted me $285 for a new radiator fitted.. some metallic core or somethingZ
the part is
$220 and labour $65
is that a good price or should i go else where ? i can actually see the crack/burnt part of the radiator so i know he wasnt b-s me
thanks
Brad`
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2008, 07:01 PM   #2
Windsor220
Now Fordless
Windsor220's Avatar
Your probably not going to get it much cheaper than that unless you do the work yourself.
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2008, 07:05 PM   #3
howesy
howesy's Avatar
If its a copper or brass core its prob a reas. price however they do sell on flea bay for around 170, see here-:
http://cgi.ebay.com.au/RADIATOR-FORD...QQcmdZViewItem
Don't go the alloy again, he is right it is common.Also, making sure the car has good earthing helps with corrosion issues.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 07:52 AM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Its your money.... but i'll just add my advise here... Unless its an ADRAD unit, it will not last...
That price screams to me that its an imported unit... and thus, ADRAD is Australian... there are plenty of threads on here that agree with me on thier quality over all others.
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 05:08 PM   #5
brad`
The Monty
brad`'s Avatar
hey yeah its going to be Brass inner
not sure what brand/make it is tho never thought to ask
so the price is about right ?
thanks brad`
Old 30-09-2008, 06:55 PM   #6
InfernoSR
InfernoSR's Avatar
thanks brad`
Price is expensive for an Import and to cheap for an Adrad unit...
Old 01-10-2008, 04:12 PM   #7
Mechan1k
Mechan1k's Avatar
You are probably going to look at around $250-ish for an ADRAD unit ... I can highly recommend them ... had a twin core in the old AU ... worked a treat under load on the really hot days.
Old 01-10-2008, 05:07 PM   #8
brad`
The Monty
brad`'s Avatar
hrm.. ill find out if he can put one of those in, if there as good u guys reckon dont mind paying the extra
thanks
Old 01-10-2008, 06:00 PM   #9
CMYAU3
Tyre Shredn
CMYAU3's Avatar
dude get the radiator but put it in yourself its easy as 20 min - 30 min if i remember it was a while ago when i changed mine.
Theres like 4 bolts or something and the thermos come straight off.
Undo all the auto coolant lines & radiator hoses. and i think the bottom plastic under the front nose also has to come off and done!!
Change it over and put it all back together
P.S get new hose clamps throw the ford ones out.
CMYAU3 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2008, 06:01 PM   #10
Mechan1k
Mechan1k's Avatar
Also need to do the transmission lines well into the radiator.
Old 01-10-2008, 06:14 PM   #11
CMYAU3
Tyre Shredn
CMYAU3's Avatar
thats easy just make sure the fittings are clean before you screw them in or they wont seal. even a small piece of dirt can cause them not to seal.
Old 02-10-2008, 05:37 PM   #12
brad`
The Monty
brad`'s Avatar
i was going to do it my self then i thought.. $220 for the part.. 20 for coolant $5 or 10 for new clamps.. = $260ish
for an extra 20 why bother least if it stuffs up he can fix it
oh the radiator place only sells RAMAD radiators 2 so its a bonus
thanks
brad`
Old 02-10-2008, 05:51 PM   #13
InfernoSR
InfernoSR's Avatar
thanks
brad`
Never heard of a RAMAD Radiator... sounds more like a Middle East Cruise Missile
Look for an ADRAD unit :P
Old 02-10-2008, 06:31 PM   #14
brad`
The Monty
brad`'s Avatar
hrmm.. must be a holden brand ? haha jk
Old 02-10-2008, 06:35 PM   #15
InfernoSR
InfernoSR's Avatar
I'd love to drop a holden out of an aircraft over in Iraq :P
Old 02-10-2008, 08:00 PM   #16
brad`
The Monty
brad`'s Avatar
haha prob do just as much damage, heavy enuff thats for sure :P
Old 02-10-2008, 08:55 PM   #17
InfernoSR
InfernoSR's Avatar
Probably not as much physical damage, but far more emotional damage LOL!
Old 02-10-2008, 09:25 PM   #18
brad`
The Monty
brad`'s Avatar
yeah i must ad mit id cry.. from laughing not to bad, nmake a mark in the ground where they belong.
