Old 15-10-2008, 11:20 PM   #1
SSD-85
Default MODS: 200kw vs 220kw
Good evening all,
Just asking for opinions on the 200kw vs 220kw xr8's for modding. Is the 220 worth the extra bucks? And does the 220's factory mods i.e: port matching, fuel system, larger valves, etc help or hinder with, say, a bigger cam or adding a blower? Also i've been searching high and low for pics of one of these that have exhausts on both sides of the rear, just want to see how it's done, how it looks, etc. any links or pics would be great cheers
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2008, 12:02 AM   #2
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
exaust can't be done. Fuel tank is in the way. The 220 is worth the extra. Try and buy those extra bits afterwards and it'll cost you more then the little extra for the 220.
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2008, 08:10 AM   #3
b2tf
not here much anymore
b2tf's Avatar
I'd actually say it depends on your plans for the car. The 220 has different heads and cam but if you wanted to put aftermarket ones in down the track then it doesnt matter if you get a 200 or 220. I have a 200 (well, it used to be a 200 anyway) and I had no dramas modding it compared to a 220.
2024 F150 XLT
Old 16-10-2008, 05:50 PM   #4
Black XR
Narooma blue XR8 ute
Black XR's Avatar
I have both 220 sedan and 200 ute both autos & while others will disagree with me the difference between the two is stuff all. While I haven't had them on the dyno or run them down the strip the seat of the pants difference is so close it's hard to tell
Black XR is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2008, 06:04 PM   #5
Peuty
Afterburner + skids =
Peuty's Avatar
Originally Posted by b2tf
....The 220 has different heads...
I thought all AU V8's (besides T-Series) got GT40P's.
Oo\===/oO
Old 16-10-2008, 06:26 PM   #6
b2tf
b2tf's Avatar
They did but as you know Yella Terra worked the heads in 220's with bigger valves etc - this is what I meant about them being different to 200 spec ones.
2024 F150 XLT
Old 16-10-2008, 10:01 PM   #7
SSD-85
b2tf, i wish to add a centrifugal supercharger at 9psi (just bolt-on), and an appropriate cam (i found something on crow cams website that seems to fit the bill). plus the things that go with them, i.e extractors, flash tune, injectors, etc. all other engine components will be stock, so is the 220 better suited to this with it's worked heads? or will a 200 be just fine? the fuel pump/regulator i think MAY need to be upgraded, not sure...all in all, this is nothing too fancy, just want a blown daily drive
On a side note, sucks big monkey that i cant have pipes on both sides.
Old 16-10-2008, 10:08 PM   #8
sly
Sly like a G6
sly's Avatar
The bigger valves of the 220 will probably help a bit with a blower. But so will the higher-ratio rockers you'd be mad not to fit with a cam upgrade. Or even with a stock cam and the blower.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2008, 10:15 PM   #9
SSD-85
Is the blower-suited cam from crow any better than the stock cam of the 220? just so you all have a better idea on what im talking about, they had a list of cams for EFI windsors incl. stock cam, and this cam im looking at has same lift as stock cam, just different timing. but when crow says stock cam, are they referring to the ye olde 185kw era windsors? in saying that, is the cam in a 220, in a word, identical to this crow cam? or better/worse?
Old 16-10-2008, 10:24 PM   #10
b2tf
b2tf's Avatar
A blower setup will work on either, its just a matter of overall numbers i.e. one might get you higher than another.
The cams side of things - the 220 stocker cam is "smaller" then the 200 spec cam but if you're going to change it anyway it wont matter that much. In all honesty for the work you're looking at doing, for me it would come down to what I could find at the time - ie if you find a nice 200 go for it, if you find a 220 go for it.
2024 F150 XLT
Old 16-10-2008, 10:31 PM   #11
SSD-85
Sounds like a plan b2tf, thanks for your input. if anyone would like to see my progress is the workshop the appropriate place to start my thread?
Old 16-10-2008, 10:56 PM   #12
UU TS50
T3 TS50 075
UU TS50's Avatar
i have seen a series 3 with exhaust out each side and it looked awesome the passenger side pipe was heat wrapped and ran inside the rear bumper and bent out under the other side sorry no pics
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2008, 08:07 AM   #13
RG
Back to Le Frenchy
RG's Avatar
Damn that would be a tight fit.
Old 17-10-2008, 11:21 AM   #14
dreadly
Mate get a 200kw and do a few things to it..... In short worth the extra $$$ NO?!
The 220kw got 1.72 YT roller rockers, the 200kw had 1.6 cranes, the 220kw got a tickford 70mm T/B,
So for 20kw which decent exhaust can fetch, get a set of 1.72 RR's a 70mm T/B, the camshaft in the 200kw is actually bigger than the 220kw cam... So i think the few grand saved on purchase price you could spend on a 200kw flash tuner, extractors etc and kill a 220kw
dreadly is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2008, 11:27 AM   #15
RG
Back to Le Frenchy
RG's Avatar
Spend the same $$$ on a 220 and it would kill the 200.
Old 17-10-2008, 03:37 PM   #16
b2tf
b2tf's Avatar
You can go backwards and forwards between the 2 following the same argument as above but at the end of the day the thing that is going to make the difference to EITHER version is the mods that you do. Now a blower is not exactly what I would call a 'bolt on" mod so you can't compare it to anything unless it's another blower. I still stick with what I said above - find whichever version has the most options ticked, is in the best condition and is the right price and buy it. That's what I would do anyway. At the end of the day it is 20kw which is bugger all if you're talking about forced induction anyway.
The build thread is perfect for the workshop builds section mate and I will look forward to seeing how you go with it all.
2024 F150 XLT
Old 17-10-2008, 03:59 PM   #17
RG
Back to Le Frenchy
RG's Avatar
And that is the best advice you will get here.
Old 17-10-2008, 09:52 PM   #18
philstoj
philstoj's Avatar
PM "grunter" on the forums, he had a awesome AU XR8 sedan that run a vortech on it, i believe it was a 200 version.
Here's a link to his site http://www.grunter.com.au/
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2008, 09:58 PM   #19
SSD-85
Yeh i've checked his website out, yes it is an awesome car. In fact, grunters' car was my inspiration, however I was hoping to use a powerdyne though (yes, i'm a tight a** haha) anyone had any experience with these units? and out of sheer curiousity, would he be the man to talk to about the technical side of it? because i'd rather talk to somebody who isnt trying to take my money first. Always hated talking about something i'm 97% sure about only to be told i'm wrong by someone in the shop :(
Old 19-10-2008, 01:01 PM   #20
UU TS50
T3 TS50 075
UU TS50's Avatar
Yes it was but it had the rebel/S3 rear bar so there is a bit more room down low
There is a S3 with a supercharger in the F/S section for $19 000 at the moment
Cheers John
Old 19-10-2008, 10:48 PM   #21
SSD-85
Just one more thing I almost forgot, can the auto box in these handle up to 300rwkw (most likely 250rwkw though, i'm not going nuts on it) without modification?
