Old 26-10-2008, 05:12 PM   #1
aussiemart
aussiemart's Avatar
Default Au xr8 s111 what valve springs to use?
As most of you know i have broken valve springs in my car not a coil, so i was wondering what valve springs people have used and has anybody found a beehive spring that will fit with no machining?
Cheers guys
aussiemart is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2008, 06:47 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Cheers guys
I replaced mine with CROW seem ok and I think Yella Terra (site sponser) do them as well
Originally Posted by Riksta
Old 26-10-2008, 06:54 PM   #3
RG
Back to Le Frenchy
RG's Avatar
Another one with crow here. They seem to do the job well.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2008, 08:10 PM   #4
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
3rd running crow springs 3777's from memory.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2008, 07:14 AM   #5
aussiemart
aussiemart's Avatar
Thanks guys will give crow a ring today, i think the 3777s are for a bigger cam but will look into it.
Thanks guys
Old 27-10-2008, 07:53 AM   #6
james22
With da Warlords
james22's Avatar
Crow springs here too. Mean't to be ok, I've heard some stories about the crane ones though... Don't want to go there
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2008, 08:23 PM   #7
aussiemart
aussiemart's Avatar
Spoke to crow today and they said the 3777 springs cant be used without head machining because the pressures are too high for a std cam and they are sending me out some xr6 ones which they said would fit straight in plus i got some chromoly retainers, hope this is all good.
Old 27-10-2008, 09:26 PM   #8
b2tf
not here much anymore
b2tf's Avatar
XR6 valve springs does not sound right to me. When I got the cam I got parts kit from Crow PN K6201 which has Valve Springs in it. I dont have the part number for these springs handy, but I can get it from the Crow Catalog at work if you need them. These are what I'd put in if I was doing mine again.
2024 F150 XLT
Old 27-10-2008, 09:44 PM   #9
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
And a set of Isky springs locks and retainers here
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2008, 01:05 AM   #10
5.0 ED
5.0 ED's Avatar
i just realise i got it backwards 7333 not 3777.
The normal crow spring kit has 7738's.
Old 29-10-2008, 08:29 PM   #11
aussiemart
aussiemart's Avatar
okay i have the correct springs now but wich side should be set heavier the exhaust or intake? it has 2 different retainers so the intake or the exhaust needs to be stiffer? i would asume the intake due to the heavier valve but im not so sure?
