Old 27-10-2008, 11:40 AM   #1
NYTEYZ
Default Lowering AU Fairmont
Hey guys, I'm lowering my Series II Fairmont with Kings Superlows and Shortend shocks, I'll Have 18's on it when i get it done but is there anything else i will need to do?? eg. Camber kit?
Thanks for the help
John
NYTEYZ is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2008, 11:46 AM   #2
Mont5.0
Mont5.0's Avatar
i went superlows with 18" on my mont. No castor kit required here.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2008, 11:51 AM   #3
NYTEYZ
How much did the superlows drop the car?
Old 27-10-2008, 12:08 PM   #4
RG
Back to Le Frenchy
RG's Avatar
Mines on Sl's all round and I didn't need a camber kit, however there is only one bloke I know that can actually get the alignment right without one. Most places say I need one.
I also have caught a guard with 245/40/18's on the front and I have to be careful with the 245/35/19's I have now, getting the front guards rolled might be an idea.
Old 27-10-2008, 03:49 PM   #5
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
NYTEYZ - I am assuming you dont have IRS rear end. Do you have any pics of your car?
I am also interested in have a similar setup like yours with same diameter wheel.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2018 Hyundai Santa Fe Highlander
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2008, 04:04 PM   #6
HLC
Audi S3
check out Mont5.0's car in the workshop build sction for pics of that combo.
Old 27-10-2008, 04:17 PM   #7
blueoval
Critical Thinker
blueoval's Avatar
thanks henry
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 27-10-2008, 06:30 PM   #8
mattp
mattp's Avatar
Same story here, I've got King Superlow with shortened shocks and haven't needed any camber kits. I've had 17, 18 and 19" wheels on there without a drama. If you want to see how it sits check out my build thread, there's plenty of photos in there. I haven't had any problems with scraping at all either, except when there's a couple of big blokes in the back (and even then it's just mudguards). Cheers.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2008, 08:41 PM   #9
blueoval
Critical Thinker
blueoval's Avatar
thats good to know matt. thanks.
Sorry to steal ya thread John
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 27-10-2008, 08:58 PM   #10
b2tf
not here much anymore
b2tf's Avatar
I on the other hand will put my hand up and say that I would not lower a car without putting a camber kit on. I have one on the XR8 and it is the best thing about the entire suspension setup.
2024 F150 XLT
Old 27-10-2008, 10:40 PM   #11
NYTEYZ
NP - Mi casa e tu casa.
To all he others thanks for the help, I'll have some picks up in a few days after i get the wheels and then after the suspension is done.
Old 27-10-2008, 10:47 PM   #12
blueoval
Critical Thinker
blueoval's Avatar
look forward to seeing the pics. ;)
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 28-10-2008, 09:08 PM   #13
mattp
mattp's Avatar
Isn't the main purpose of a camber kit to allow for more adjustment if the 'stock' set-up doesn't go far enough to align the wheels satisfactorily? Therefore if it can be adjusted enough, you don't need one, so what would you gain by putting one on? My understanding is that the main benefit of adding a camber kit is preventing the tyres from scrubbing out on the inside edge, but handling would actually be better in this set-up, with better turn-in. So it's a balance between tyre wear and handling.
So in my case, adjustment was adequate and tyre wear is satisfactory, so would I benefit from adding a camber kit?
Is this a fair assessment? Please correct me if I'm wrong.
Old 28-10-2008, 09:14 PM   #14
MADED-6
MADED.6
MADED-6's Avatar
usualy with a bit of camber u get alot of tram lining as in the car follows lines in the road and will pull a bit but if u dont have that and ur not chewing tyres the it will be fine.
mine with my special springs in it has 2 degree negative camber at all 4 corners and with anything other than stockies tram lines all over the place.
but i will be getting springs shocks and camber kits soon.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2008, 09:30 PM   #15
RG
Back to Le Frenchy
RG's Avatar
Nope, you summed it up nicely. Mines the same, don't need it so didn't get it.
Old 29-10-2008, 10:41 AM   #16
blueoval
Critical Thinker
blueoval's Avatar
I was in 2 minds as to whether I need this or not. But I reckon I'll get the camber kit only if the car needs it.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 29-10-2008, 11:13 AM   #17
NYTEYZ
I'm the same.
On another note i finally found someone to fit the suspension this week.
I rang TTF in sunshine and they could do it until i told them the springs were off another car.
TTF: Do we need to order the springs and shocks for you or have already got them?
ME: I already have them, Springs have about 1000km on them, shocks are new.
TTF: sorry we don't install secondhand parts.
ME: What??
TTF: we don't install second hand parts.
ME: *hangs up phone*
Old 29-10-2008, 11:26 AM   #18
Mont5.0
Mont5.0's Avatar
clean the springs up (1000k old shouldn't be that dirty) wrap em in pairs in glad wrap, take em there say thats how you bought them.
Old 29-10-2008, 11:31 AM   #19
NYTEYZ
I don't think i could get them much cleaner, they still have the code printed on them, the rears actually still have the lable on them for the code.
Old 29-10-2008, 11:32 AM   #20
blueoval
Critical Thinker
blueoval's Avatar
I think the reason why they dont like second hands parts is:
a) they dont make any money on them
b) they dont warranty the 2nd hand parts
c) they may have had issues in the past with fitting second hand materials.
Wouldnt let that worry you. Try somewhere else. Any mechanic can do it, it doesnt have to be a wheel mob.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 29-10-2008, 11:35 AM   #21
NYTEYZ
I've a suspension mob in brooklyn doing it tomorrow for $140 all up.
Old 29-10-2008, 11:40 AM   #22
RG
Back to Le Frenchy
RG's Avatar
The problem is you called TTF Sunshine. They are absolute morons there, I nearly got into a fist fight with the manager there because he tried to tell me it was my fault they put the wrong tyres on my car. All I did was go there to swap the Bridgestone GridII's that I had put on at Cheltenham TTF (I had asked for and paid for GIII's) and the bloke at Sunshine said he had a set (Cheltenham organized it). Got there and he tried to put Grid II's on it, then said he was doing me a favour and that I should take them and shut my mouth before he shut it for me.
Sunshine TTF is bad.
Old 29-10-2008, 11:51 AM   #23
blueoval
Critical Thinker
blueoval's Avatar
WHAT THE F......???
thats is shocking beahviour. Terrible business practice. Thats sad to see.
John - thats god to see you have found another place. $140 fitted isnt bad. Does that include a wheel align after?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 29-10-2008, 11:53 AM   #24
NYTEYZ
No wheel align with the price, extra $20 which i'll get done
Old 29-10-2008, 12:15 PM   #25
blueoval
Critical Thinker
blueoval's Avatar
thats cheap for a wheel align. Is that with the same place?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 29-10-2008, 08:47 PM   #26
b2tf
b2tf's Avatar
No you're pretty well spot on. My kits were on the ute before I bought it but I have them adjusted every time I get the wheel alignments done and they do sometimes need a little bit. In my opinion they are a good thing to have if your car is lowered but if, as in your case, there is no need for one, well I probably wouldn't bother either.
2024 F150 XLT
