Old 06-11-2008, 12:58 AM   #1
Bolly
Bolly's Avatar
Default What is the right tyre pressure??
The car is a 2000 AU2 XR8... Dealer fitted Noisy Crappy Directional tyres just before i bought the car... Once i got the car home i checked the tyre pressure...which was 45psi all round. Dropped it to 32psi all round and it drove a bit softer, but tyres started to wine..which is annoying..
7,000 kilo`s later i noticed both front tyres were wearing badly on the inner side of the tread..
With the car just clocking 38,000 Kilo`s i woundn`t think there was much suspension wear..
So i went to a suspension & Wheel Alignment shop and was told the alignment was perfect and the wear was due to crapy tyres and low pressure..
He told me to run 40 psi all round which i thought was too high?? With
his personal car he runs 50 psi..which was a T3 with a XR front, super lows,18 inch rims running 245`s at the front and 265`s at the rear..450KW at the flywheel,Rotors were so large that he had to machine the inners of the rims to get them to clear..
Caliper`s were massive, No Plate had STABLE 1...
The car looked pretty tough,colour was silver.. One Tough car!
Bolly is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2008, 01:31 AM   #2
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
With lower profile and wider tyres you do normally run more pressure, in yours i'd run 38psi assuming they are 235/45/17's.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2008, 07:13 AM   #3
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
I have high pressures in mine, anywhere from 40 to 44.
Less than 40 and they squirm too much and wear uneven.
Tyres are far better off with more pressure rather than less.
They last longer, handle better, are quieter, protect the rims more, and provide better fuel economy.
On the track I have run 50.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2008, 08:35 AM   #4
whiskers
gone fishing
whiskers's Avatar
I was told to run 36 psi in mine and they are a standard Perelli
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2008, 11:35 AM   #5
TE50 027
Tickford Tough
TE50 027's Avatar
I run 40psi on the street in my 235/45/17's with no probs.
Off topic but why the heck would someone do this to a T3?
Originally Posted by Bolly
With his personal car he runs 50 psi..which was a T3 with a XR front, super lows,18 inch rims running 245`s at the front and 265`s at the rear..450KW at the flywheel,Rotors were so large that he had to machine the inners of the rims to get them to clear..
Sparkling Burgundy T1 TE50 Build #027 - SOLD
TE50 027 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2008, 12:49 PM   #6
broken_suave
broken_suave's Avatar
Even with my 205/65/15's I run 38-40psi. Just feels more confident on the road, anything less and it really accentuates the boaty suspension.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2008, 07:14 PM   #7
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Once a tyre starts to wear on the inner/outer edge, it ussually will continue, are you sure the allignment is spot on, AU XR's are bad for inner tyre wearing, mine did the same, but the allingnment was out, only just though.
Have it checked by a reputable place.
I run 38psi in mine.
Old 09-11-2008, 08:40 PM   #8
Bolly
Bolly's Avatar
Went to Bridgestone and they said the same thing...too low pressure and cheap tyres,,And like you.... Galaxy XR8... They said to run 38psi
Cheers Guys
Old 09-11-2008, 09:04 PM   #9
GS608
would should you be running in 245/40/18s?
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2008, 12:28 AM   #10
Bolly
Bolly's Avatar
235/45/17' Xr chief
