Old 10-11-2008, 09:22 PM   #1
BoostedT
Default Gearbox Question
Gday Guys ,
Having a Bit of Trouble with this Gearbox i Purchased off Ronza , the new Auto has done "90xxxkms" .. Its been Installed and seems to be Playing Up ,
When it was being installed , the Speedo Wires were crushed without knowing , i Picked the Car up from a Mates house it had no Speedo , and was Slipping really bad ( Not enough Oil , Problem Fixed ) ..
After a Generous Top Up of 95LE Fluid , The Car Kept Jumping into Limp Home Mode , and I Realised the Speedo wasnt working , Jumped on the Forums , seen the Article about if the Speedo isnt Working , and the ABS Sensor is Activating , then the Trans goes into LHM ..
Now , thats all very well and all , Heres My Conundrum (problem) ,
A good Mechanically Knowledged Mate , Fixed the Split Wires on the Speedo Line (Red Heat Sheilded Cord from Top of Auto to Wiring Loom , 3 Prong Plug ) , We Connected it , and i took off , Viola ! My Speedo Works again , but he Car Remained in LHM ..
We Disconnected the Battery for a good 10 Minutes , and Let the Car Venture through the 15 Minute Startup Sequence , Took it for another Test , LHM again ..
So what do you guys Reackon .. Its really got me Pinned .. I find it hard to believe that it could be the box with so Low K's on it , the Oil inside was really clean .. If anyone can Rectify the Problem , Ill Re-Imburse them for their time ..
Thoughts Would be Appreciated ..
Daniel
BoostedT is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2008, 10:26 AM   #2
BoostedT
no one ?
Old 11-11-2008, 10:35 AM   #3
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
Mate their could be many reasons for it to be in limp home mode, all due to electrical connections, double checking the main wiring plug on the side into auto would be the first thing, 2nd is that the shift postion switch on the side with the inhibitor switch as well do play up.
Do you know how to use a multimeter?
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2008, 12:06 PM   #4
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
Battery has to be off for 45 min i think at least for the computer to do a full reset. Best bet leave it over night and see what happens.
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2008, 05:07 PM   #5
BoostedT
Multimeter i can use , so you basically though , your telling me to Clean and CRC all the electrical Connections ,
then do a full Overnight Reset
Yeah ?
