04-12-2008, 09:11 PM | #1 | ||
G'Day,
In my bordem and curiosity I came accross an SS induction throttle body on ebay. You see everyone trying to make their intake larger so they can get more air in.. So in theory increase TB and have 3" inatke you will get even more in. My question is would this munt the A/F ratio's and would this make the car run too lean? Say on a basically stock car. Larger cam, bigger fuel pump, Intake modified, and headwork. Would this be a good idea in the chase of a decent time slip? Ebay
Daily: AU Forte Wagon Project: AU Fairmont - Wants to be turbo The Family Car: 2009 G6E Turbo Future fun: 1968 Ford Galaxie 500 |
04-12-2008, 09:16 PM | #2 | ||
04-12-2008, 09:21 PM | #3 | ||
not here much anymore
Not worth the dollars in my opinion, I think the general consensus is that the stocker is a good enough size for a 6cyl. If a 70mm one will support 200+ rwkw on a V8, why would a 6 need bigger?
2024 F150 XLT
04-12-2008, 09:24 PM | #4 | ||
According to JMM, larger t/b's on a n/a i6 is pointless, unless your getting head work done. The reason being whilst you may increase airflow to your heads, your i6 inlets are still only a certain size, and the factory one (up to an au at least) is the "best" one. Correct me if i am wrong anyone.
04-12-2008, 09:28 PM | #5 | ||
It does make sence why it doesnt work. Just trying to get my head around it a little better.
Like everything is pointing to its not worth it, but has anyone tried using larger TB or tried anything in that area?
04-12-2008, 09:34 PM | #6 | ||
www.jimmockmotorsport.com , basically everything one could do to the N/A SOHC i6, he's done. and read the articles (found on the site) about the work he's done, quite amazing really.
04-12-2008, 09:48 PM | #7 | |||
2024 F150 XLT
04-12-2008, 09:54 PM | #8 | |||
04-12-2008, 10:11 PM | #9 | |||
2024 F150 XLT
04-12-2008, 10:26 PM | #10 | |||
OzEcruisers PRESIDENT
Some one tested a larger throttle body on FordMods - be that it was a 68mm not a 70mm one but still has results CLICK HERE
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
04-12-2008, 10:41 PM | #11 | |||
You can't stop the signal
Not worth it at all.
Our motors at full noise (6000rpm), with 100% volumetric efficiency (impossible without boost), will want to consume about 12,000 L/min (liters of air per minute) A circle restrictor of 50mm, which is smaller than our throttle bodies, will flow a maximum of about 23,600 L/min. So right there you can see that a larger throttle body is not needed. Where it comes into play is the air velocity through that "restrictor". The lower the velocity, the more laminar (smooth) the flow is, which means the less "moving" air their is in the plenum. The less moving air, the less work the motor has to do to move it. Less work on the motor, more power. But the higher the velocity, the more turbulent the air is, which means better mixture mixing. Better mixing, more torque. I'm not a pro on this yet (currently studying mechanical engineering), so my knowledge is limited and possibly wrong. Cheers
05-12-2008, 07:50 PM | #12 | ||
i opened the throttle body up on my car but left the butterfly standard and i picked up throttle response thats about it.
06-12-2008, 07:55 AM | #13 | ||
RIP...
'superroo' is spot on.
The CFM requirement of our little 4L is less than 400cfm at 6000rpm. Even at 7000rpm we're talking less than 450cfm. This is based on 90% VE, which is a pretty serious street engine. Standard engines are around 70%, mild engines are around 80%, and heavily modified street engines are around 90%. Race engines can be 100% and more. Our standard TB's flow around 550cfm. Even at 8000rpm and 100% VE, our engines only require just over 550cfm. Clearly a bigger TB is not needed. All a larger TB will provide is touchier throttle, because at small throttle positions the large TB will be flowing more than a smaller unit. So we think throttle response has improved.
. Oval Everywhere... |
06-12-2008, 08:47 AM | #14 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
06-12-2008, 12:54 PM | #15 | ||
i have a ported and polished TB with the standard butterfly...
didnt feel much difference... maybe a bit more throttle response... but id like to think it makes some what of a difference.. now just need an airbox for my pod filter
11-12-2008, 05:20 PM | #16 | |||
Smile
A 65mm acufab flows to 616 cfm A 70mm tb flows to 726 cfm. Our throttle bodies must flow around 680 cfm at 68 mm. Why did ford do this? They knew it wouldnt spin to 12000 rpm... Our cars at 6000rpm need 390cfm!!
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again Last edited by Stav; 11-12-2008 at 05:26 PM. |
11-12-2008, 05:38 PM | #17 | ||
Broken
What a total waste of money a bigger throttle body would be on a n/a I6.
Even the ooo's and rrrr's from the boys at the pub would turn to wtf : if they new just a little bit about these engines. Maybe it would be good cred at some schoolies leavers party? Or show and tell at kindy.
The Scud GT 11.4 @ 128, 1.88 60ft. |
