Old 14-12-2008, 03:21 PM   #1
DJM83
Barra Turbo > V8
DJM83's Avatar
Default Climate control A/C
The A/C is playing up in my TE, sometimes it just doesnt engage when you press the AUTO or A/C button. Other times it does. Any ideas?
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 15-12-2008, 08:46 AM   #2
whiskers
gone fishing
whiskers's Avatar
get the refrigerant checked it could be low.
Whiskers
Old 15-12-2008, 09:25 AM   #3
DJM83
Barra Turbo > V8
DJM83's Avatar
If it is low the compressor it should still engage but just push out hot air. When it does engage it works fine.
Old 15-12-2008, 09:28 AM   #4
BIGJB
BIGJB's Avatar
If it was me I'd be looking at the obvious 1st.
Have you checked the wiring coming out of the compressor?
Unplug it and replug just in case there is dirt or water i the contact.
With all the rain lately it may very well be dirty connection if water
has splashed up there. (not like its a part you would normally clean)
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2008, 09:53 AM   #5
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Have you tried the climate control reset thing to see if any error codes come up??? I think its pressing each button at the end (vent position & Off (IIRC)) at the same time. Also i would be checking the plug into the actually climate control unit, maybe it has come a little loose if its been out before. Just a thought.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2008, 11:25 AM   #6
sbcb
BA Xr8
sbcb's Avatar
Always try the free reset option.
http://www.fordforums.com.au/showthread.php?t=11241093
sbcb is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2008, 02:11 AM   #7
Umineko
Karasu
Umineko's Avatar
Actually it won't there is a pressure cut off switch which will dissengage the compressor if the refrigerant pressure falls below a certain level, the engine idle will increase as it should when the A/C kicks in but the electronic clutch on the compressor will not engage
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2008, 09:49 AM   #8
DJM83
Barra Turbo > V8
DJM83's Avatar
Might be getting low then because it is sarodic in its operation
