Old 24-12-2008, 11:13 PM   #1
ed ant
ed ant's Avatar
Exclamation throttle position sensor
we have au 3 sr wagon we change the battery and now it stalls at round about it idles ok when put in gear it playes up autobox but when i unplug the throttle sensor out it comes good
black ed lowerd king springs 16" mags pioneer sound system. :
ed ant is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2008, 12:40 AM   #2
Cam
Stroking it...
Cam's Avatar
seems strange, how long ago did you change the battery?
Its normal for a car to run roughly for a few hunge k's after a ECU reset, but not sure that i have heard of it being sorted by d/c the TPS, so we might need more input here
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2008, 07:25 AM   #3
au2sw
Blown 5L coming
au2sw's Avatar
there is a procedure to follow after ECU rest that will get the car running properly before driving any where. theres a thread on it here somewhere, just havent looked for it as yet. The car needs to learn the driving style again after a reset so just leave everything plugged in (you can actually bring up trouble codes if you go unplugging things left right and center) and drive it normally, as mentioned above, it will come good in a couple hundred ks.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2008, 09:22 AM   #4
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
Yep you should not be disconnecting the TPS, it will cause it to run at higher rpm due to a fault code being listed.
So disconnect the battery again for over an hour and then re connect it and do the re leard procedure.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2008, 08:11 PM   #5
GK
Walking with God
GK's Avatar
This is the procedure.
Resetting of AU ECU
http://www.fordforums.com.au/showpos...9&postcount=85
Hope that gets it sorted for you.
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
