Old 26-07-2005, 10:30 PM   #1
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
Question Brake Upgrade
hey ALL
i've got a couple of questions to ask.
I have a EB series 2 I6 with stock brakes that shudder i want to up grade instead of machining again.
1. i want to up grade my brakes but in a simple way. ive been told that V8 brake boosters work better than stock I6 ones. is this true?
2. what are the cost of slotted rotors? and are they much better?
3. is it possible to easly adapt later model brakes to my car eg:AU?
thanks heaps. :1syellow1
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2005, 10:46 PM   #2
niko
likes falcon's
niko's Avatar
i would think slotted rotors, and good pads would be cheapest and easiest upgrade
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2005, 11:04 PM   #3
Simmo
White Lightning
Simmo's Avatar
if you were lucky you could find an el gt set but youd need rims to fit the huge rotors in. go slotted [and crossdrilled if you want] and get some good pads. it will cost you a fair bit to fit AU brakes which arent any bigger i dont think? and yes the v8 boosters are a bit better.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2005, 11:10 PM   #4
LG
LG's Avatar
AUII/III had a Twin-Piston Setup up front. I'm selling my ones, if you are interested.
To further make the conversion to the twin-piston setup, you will also need:
- Aftermarket Swaybar (& Possibly Swaybar Mounting Points)
- 16" Wheels or Greater
- Lower Control Arms
- Uprights
Theres a bit involved, but slotted rotors and different pads, would be the cheap route, and would still be pretty good on the street. Although, my AUIII did pull up a fair bit harder compared to my mates AUI, which has the same brakes as you.
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2005, 12:24 AM   #5
INJECTED_250
Custom user title
INJECTED_250's Avatar
the lower control arms from an au wont fit in an eb.... so that turfs any idea out the window of using the au set up...
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2005, 06:02 AM   #6
NZ
NZ's Avatar
Yeah whole K frame is needed.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2005, 07:38 AM   #7
LTDHO
The one and only
LTDHO's Avatar
Originally Posted by ebmanul
hey ALL
I'll be going bigger and better on my LTD some time this year due to it current power. Currently I have slotted disks with GreenStuff pads. They are not really good when trying to stop a 340kw LTD but will be perfect on a I6 EB.
Tuned by CVE Performance
Old 27-07-2005, 08:50 AM   #8
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
thanks guys i think i will just go the slotted rotors with some nice pads and a v8 brake booster.
Old 27-07-2005, 09:09 AM   #9
INJECTED_250
Custom user title
If u use au k-frame then u need au sterring rack, and then the stering coupling wont fit, yada yada yada.. the list goes on. Id go the sloted rotors and good pads
Old 27-07-2005, 09:25 AM   #10
parawolf
beep beep
cebco brakes to an upgraded full package for e-series. While it isn't 'cheap' it is complete.
For $2700 + fitting (all the parts included, you could do it yourself) you get PBR twin piston calipers, pads, braided lines and sizable 330mm discs (also includes brake fluid and other things I haven't mentioned.
If you are serious about proper performance braking they also do a 4 pistion AP Racing kit for $3995.
Both of these are front only kits which do 80% of your braking capacity anyway. Good pads, braided lines and clean fluid are all that are really required until you start track racing, and even then upgrading to some grooved and vented discs at the rear will be 99% of your needs.
www.cebcobrakes.com.au
40-42 Mills Road Braeside
3195, Vic, Australia
Phone: 1300 55 66 40
Fax: (03) 8586 2510
Email: john@cebcobrakes.com.au
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2005, 10:03 AM   #11
dansedgli
dansedgli's Avatar
Fax: (03) 8586 2510
This kit is awesome, I have the 4 pot AP racing brakes on my AU and it stops awesome!
Dont get the rears though! If you get the rears you lose the ability for getting cheap burnout rubber! It sucks!
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2005, 10:06 AM   #12
parawolf
beep beep
AHAHAHA good call
Old 27-07-2005, 10:29 AM   #13
LTDHO
The one and only
LTDHO's Avatar
You can't tell me your car can't do a burnout!
Parawolf - thanks for the info.
Old 27-07-2005, 10:34 AM   #14
dansedgli
dansedgli's Avatar
Of course it can, I just cant afford the rubber that it turns into to smoke! :nutsycuck
I miss having a spare set of 14's to go on! :SaiyanSmi
Old 27-07-2005, 01:27 PM   #15
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
nah i don't plan on spending that much im omly a student with no money!!
but the apeal of nice huge stompa brakes is damn nice. i think i will just stay cheap as for the moment.
