26-07-2005, 03:57 PM | #1 | |||
MONTY is Alive !
im in the middle of my mpfi conversion and want to know where the fuel pump is located on the multi point engines and advice on buying new ones would it improve performance or just enhance it ???
1988 Ford Fairmont EA Series 1 MODS: Hurricane Extractors, Red dash light, Fake Xenon Lights, Mpfi Conversion, Dumpage, 17" ANZ Mayhems (Chrome) TO COME: 5 speed trans, 4.11 LSD, Carputer, Stage 2 cam, Major Head Work . : |
26-07-2005, 04:08 PM | #2 | ||
PM me if you want
In the petrol tank
lift boot carpet undo 8 screws holding down metal plate back left get the lock ring off, screwdriver + hammer + patience and effort lift out the fuel pump and replace buying new wont do much, if your injectors are not using the fuel, it just goes around in a circle and back to the tank, so unless you plan bigger injectors and big cam, save the money if you can.
27-07-2005, 06:08 PM | #3 | |||
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
are converting to mpi u will need a mpi pump as they pump out 200 psi as cfi pumps out 100 psi so the car will not run properly it will not idle etc.
HOME BREW BEER SWINDLING PROFFESIONAL P-HEAD. TO MANY YEARS IN THE MAKING : :1syellow1 |
27-07-2005, 11:25 PM | #4 | ||
Low and Loud
My advice is if your going to swap your fuel pumps over, get a new stock MPFI fuel pump. Ive used 4 second hand ones so far and they all seem to die after a while.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
28-07-2005, 01:55 PM | #5 | ||
fuel pumps that have been left to dry out over time need to be imersed in petrol for a bit before installing to the tank,,this is to rejuvinate the seals and ,,if you don't it won't last long as you've found out..
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds: |
28-07-2005, 02:00 PM | #6 | ||
PM me if you want
The 2nd hand EF pump I am running at the moment came from the wreckers to home and then into my tank it has been fine so far, not a sign of a problem, my old pump was still going and when I pulled it out I reckon it was the orginal one.
