Old 16-03-2009, 04:53 PM   #1
AU00XR8
AU00
Default Cam Angle sensor.. Help please.....
Hi all,
Well i have been having problem with my series 2 XR* 200kw. The codes have been scanned and the error is Cam Angle Sensor. I have just got off the phone wityh ford and they have qouted me 10 hours at $110hr. Oh and that does not include the sensor. So as my mechanic can't do it, can anyone point me in the direction of a good mechanic who can do it cheaper than Ford.
AU00XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2009, 08:32 PM   #2
Papa Smurf
Papa Smurf's Avatar
Depends on what PART of Sydney? If in the Penrith Area I would tell you to go to ALL West CV, Phone 4731 2083 and ask for Darren or Jason and see what they say?
In Granville/Parramatta Auto Tech Engineering. http://www.autotechengineering.com.au/
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2009, 09:05 PM   #3
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
10 hours? To remove the engine cover, remove the coil packs, clean the top of the block, remove the cam sync, replace it and then refit all components?
6 hours MAX, and that includes the calibration procedure.
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2009, 10:10 PM   #4
BJ TE50
BJ TE50's Avatar
What problems are you having with the car? I pulled the engine cover off on my xr8 the other day and found the wires to the cam angle sensor have snapped off. The engine seems to be running fine though...
Just had a look at the Ellery's manual and there is no way it would take 10hrs to replace. I cant see how it would take more than 2 hrs??
BJ TE50 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2009, 12:55 AM   #5
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
Yeah but just cause the fault code comes up as cam angle sensor doesn't mean a great deal, these also suffer from worn timing chains which then put the cam angle sensor out of alignment, we've had one here from memory it had only done bout 200,000kms too, put a new timing chain on did a reset and no more cam angle sensor fault.
But its a job that shouldn't take anymore than 2hours to replace the cam angle sensor, at which if it is the actual sensor that is faulty, u can get away with just replacing the sensor itself, as in the top black half as long as the bottom is worn enough in the bearings that it has caused the trigger to hit the sensor.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2009, 12:57 AM   #6
EvilChief
Boost Addict
Daniel
lol an that should include lunch hour too
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2009, 11:04 AM   #7
BillC
Ultra Tune in Townsville just replaced my CAM angle sensor last Thursday and charged me $107 for the sensor and 1/2 hour labour to fit it. $150 something dollars. That included the diagnosis as well. Its a real easy job. Ford are ripping you off.
BillC is offline   Reply With Quote Multi-Quote with this Post
