Old 18-03-2009, 12:20 PM   #1
ford_maiden
5lt fairmont ghia
ford_maiden's Avatar
Default Idle problem
when my car is sitting in gear it will drop its revs down to about 500 and then after a couple of nimutes will pick back up to 750, can anyone please tell em why it might do this?
this generation of car enthusiasts didnt invent the art of 'cruising' , 'cutting bog laps' , 'racing' and 'burnouts'. its funny how the past generation or two stardted it and now are the ones handing out the fines
AU II FAIMONT GHIA " TIX35" 5.0lt
ford_maiden is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2009, 01:47 PM   #2
GK
Walking with God
GK's Avatar
A number of things could be causing what you're describing.
Dirty fuel, dodgy or dirty plugs, a crook lead, dirty air cleaner, dirty throttle body, dirty IAC (also known as ISC), coil pack on the way out, dirty fuel filter.
Firstly I'd clean the IAC/ISC. Easy and cheap to do. *Many idle issues are caused by this being dirty.
Cleaning ISC Valve
http://www.fordforums.com.au/showpos...9&postcount=43
Then I'd clean the Throttle body. This is for an I6 but the iside of the TB will look about the same as a V8. * As above.
Cleaning Throttle Body
http://www.fordforums.com.au/showpos...2&postcount=48
Then I'd check your air cleaner. Give it a bit of a tap and see how much rubbish comes out of it.
Then I'd check your plugs. If you use the NGK $5 items, then replace the lot. Cheap and easy enough to do.
If all that fails then you could reset the ECU.
Resetting of AU ECU
http://www.fordforums.com.au/showpos...9&postcount=85
If the problems still persists after resetting the ECU, then I'd get the leads tested and perhaps changed.
If the problem still persists, change the fuel filter.
Changing Fuel Filter
http://www.fordforums.com.au/showpos...3&postcount=37
If all that fails, then take it to a trusted mechanic who can scan for fault codes. I'd be utterly surprised however, if you needed to after working down the list! LOL!
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 18-03-2009, 05:23 PM   #3
JMO
JMO's Avatar
I've worked through that list and more! :P Still can't figure out why it's idling rough :( Best of luck with it
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2009, 07:10 PM   #4
GK
Walking with God
GK's Avatar
ISC/IAC might be stuffed.
GK
Now gone!
On LPG
Old 18-03-2009, 07:51 PM   #5
aye you
The Origional, The Best
aye you's Avatar
dropping down then moving back up again, could be the aircon compressor kicking in and out?
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2009, 08:03 PM   #6
GK
Walking with God
GK's Avatar
Shouldn't drop that low though.
GK
Now gone!
On LPG
