Old 15-03-2009, 07:42 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default How much of a sedan exhaust is useable in a wagon?
Hi All,
Just doing a few sums on a project I have in mind, and I'm wondering if anyone knows exactly how much of a sedan exhaust is useable in a wagon?
I'm guessing somewhere up until the cat, or just past it is definitely useable, but what I'm wondering is with minimal chopping, and adding extra of course, can I use the rest of the sedan exhaust?
Also, anyone know what the maximum pipe size that will clear over the diff in a wagon?
Thanks, and appreciate any advice as always!
Justin.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2009, 07:56 PM   #2
5LGhiaWgn
5LGhiaWgn's Avatar
Im pretty sure the center section can be used, its just the rear section as it has an extended section to get the tip out to the rear bar. You may be able to find a ute rear section i cant see why wagon and ute tail sections wouldnt be interchangable
5LGhiaWgn is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2009, 03:45 PM   #3
T-Pak Addict
Jim
T-Pak Addict's Avatar
Just a note just in case you didnt know EA-AU I6 are the same unless you have IRS....
Wagons are longer but should be the same upto the muffler before the diff
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2009, 09:58 PM   #4
au2sw
Blown 5L coming
au2sw's Avatar
exhaust is the same from manifold to diff if you use fairlane, other wise the wagon is a bit longer then the falcon sedan. the tail pipe is wagon specific though. ute tailpipe will not fit. spare is in the way. i have a 2 1/4 system in mine, but i know you can get 2 1/2" over the diff.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2009, 10:12 PM   #5
private9
private9's Avatar
Thanks for the info guys.
Any idea if you can get bigger over there?
Old 22-03-2009, 12:15 AM   #6
T-Pak Addict
Jim
3inch is the biggest I have seen on a ED, so should be possible, might be tight tho
Old 22-03-2009, 03:49 PM   #7
private9
private9's Avatar
Thanks mate.
Hoping to squeeze a 3.5 over there if I do go ahead with anything. It sure does look tight though.
