Old 07-04-2009, 09:43 PM   #1
FC:LTD
Default Will towing regularly effect tune
I have an au v8 manual ute .Since my landcruuiser gearbox broke about 3 months ago i have been towing the work trailer with the ute. Now i have noticed that when towing it pulls strongly from 800rpm or so, but when not towing it seems to splutter any where under 2000rpm when given too much throttle.I'm just wondering if the computer has learnt the load of the trailer ?
FC:LTD is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2009, 10:50 PM   #2
EvilChief
Boost Addict
in a word: yes
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2009, 07:42 AM   #3
whiskers
gone fishing
whiskers's Avatar
what evil chief has said
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2009, 01:26 PM   #4
broken_suave
broken_suave's Avatar
Yeah I was using my Falcon to tow a 13ft cage trailer, and when the trailer was disconnected the car felt lethargic and unwilling to respond. It also used excessive amounts of fuel for another 2 tanks after I had finnished towing. Only got about 280kms out of the first and 300kms out of the second.
I reset the ECU and after 20 minutes of driving around and letting it re-learn, it was back to normal.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2009, 10:01 PM   #5
FC:LTD
how do you reset the ecu?
Old 08-04-2009, 11:45 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Take the cable off the positive battery terminal for 20 mins or so.
Old 09-04-2009, 07:20 AM   #7
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
I tow regularly and have done so with EFI Fords for the last 15 or so years.
The ECU changes parameters slightly when towing, however it also reverts back to normal when not towing.
It's nothing to worry about and does not need a ECU reset.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2009, 07:32 AM   #8
whiskers
gone fishing
whiskers's Avatar
here is what you do and the re-learn
disconnect the battery leave it for 1/2 to 1 hour then re-connect the battery and do what is listed below, don't forget to use you hand brake
Start the car,
Idle 2 min in park a/c off,
Idle 2 min in D a/c off,
Idle 2 min in D a/c on,
Idle 2 min in Park a/c on,
Drive under various throttle conditions
Whiskers
