09-04-2009, 12:32 PM | #1 | ||
gone fishing
Hey guys,
well I just put in a new coil pack to see if it would fix my problem, see other thread. anyhow I have just finished it put everything back where its supposed to be,started the car and now the speedo is sitting at 10kph with the engine running the car is not moving or in gear. I have a series 1 with about 270k's When I changed the col pack I disconnected the battery so I still have to do a re-set thing,, it's the speedo that is now worrying me hope you can help so I can get any parts that I may need today cheers
Cheers Whiskers |
09-04-2009, 12:51 PM | #2 | ||
Irregular member
Have you tried putting the old coil pack back in to see if the new one is the source of the problem?
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
09-04-2009, 12:59 PM | #3 | ||
gone fishing
not yet I have only just finished it and seen that the speedo was reading the 10kph I will go and give that a shot after I have had lunch, what else do you reckon it could be if it's not the new one?
Cheers Whiskers |
09-04-2009, 02:10 PM | #4 | ||
gone fishing
I have just put the old coil back on and the problem is still there, any suggestions now everything has been connected up properly and there are no spare parts : so this has got me stumped I will put the new one back in and do the ecu re-set and see what happens it should be ok to drive to toowoomba on saturday
Cheers Whiskers |
09-04-2009, 02:33 PM | #5 | ||
Undo the electric plugs on the side of the transmission, and give them a liberal spray with RP7/WD40 etc, then reconnect. The speedo has nothing to do with your coil pack, and everything to do with the transmission plugs.
Did you take it for a drive? Did the speedo work properly?
09-04-2009, 03:02 PM | #6 | ||
gone fishing
I haven't taken it for a drive as yet. I have just finished putting the new coil pack back now and about to do the ecu learn process and then I will take it for a drive a see what happens then if everything settles down I will let you all know.
thanks for all of the advice Dauphin and JC muchly appreciated. cheers
Cheers Whiskers |
09-04-2009, 03:52 PM | #7 | ||
gone fishing
it seems that the problem with the speedo disappeared after I done the re-set and took the car for a drive, thanks for the help and advice it really did help. as I have never had any problems with the car in 10 years and it sort of worried me a bit, what a difference a new coil pack and leads make, its like driving a new car again.
cheers
Cheers Whiskers |
09-04-2009, 05:23 PM | #8 | ||
Irregular member
Glad to hear you have fixed the problem. I had never heard of that problem before. Does the new coil pack make it seem any different (apart from starting first time)?
09-04-2009, 05:53 PM | #9 | ||
gone fishing
yep there is a marked improvement in power and response its like having the car new again
Cheers Whiskers |
