Has anyone ever used this as a rust prevantitive? I remember seeing a show on the ABC a few years ago, they interviewed people who used the stuff commercially who raved about it both as a rust prevantive and lubricant for heavey machinery
http://www.lanotec.com.au/ |
i think dad and i used it on the rollers for his boat trailer. if not a very simlar product. seems to work pretty well
I'm more concerned about the rust prevention side of things in hard to get to places so I only have to do rust work once
![]() Join Date: Dec 2004
I've always stuck to fisholene 1st to run into the crevices the follow up with Tectyl . Tectyl is a proven product and lasts many years .
I have seen that stuff you mentioned and curious myself on how good it is . Sort of like still deciding iif POR15 is necessary or if a rust converter followed by fish oil and tectyl is just as good . |
Falcon RTV - FG G6ET
![]() Join Date: Mar 2007
Lanolin products are performing remarkably well.
A company which operates ferries from Port of Bris to Moreton Island have saved huge expenses in fuel using lanolin products as an anti fouling on their ferries ( fast Cats). Lanolin is an excellent, anti-fouling, penetrene, anti-friction, anti rust product.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
handsomest man in showbiz
Maybye,maybye not....though i've never seen a rusty sheep
What kind of rat bastard psychotic would play that song right now...at this moment?............. R.I.P. Dr Thompson... '72 GS |
#7 | |||
![]() ![]() Join Date: Jun 2006
POR15 is different, its a system that neutralises the corrosion, then seals it all off with a hard coating that prevents moisture and air getting to the affected metal surface. You use it if you want to do a more permanent fix, but you need to be able to get to the corroded surfaces so you can clean off the surfaces before applying the corrosion preventative paint. I have heard of the Lanolin based corrosion preventative compounds and people have raved about it, but have never used it myself. Read Burnedouts post above ^^^^which says its good. |
playing in my big shed
i have used a few different lanolin products myself. seem to do their job very well.
a few years back when i was in the auto rust proofing business i did some experiments by grinding the surface coating off new mild steel plates and painting them with different rust prevention products. i had several different professional type products , ie: wurths, wax gard, endrust, shield 21, nil rust, protection australia and some others that i forget their names now. i also did a sample using just lanolin liquid and left them hanging on the back fence at maroochydore for 6 months. i was surprised to find that out of all the products, the 3 that seemed to work best were wurths yellow wax (used by mercedes etc), waxgard ( now owned by the same lot that own ming) and the lanolin. some of the name products performed rather sadly. the lanolin is very good for getting into body joints and tight spots. it can be a bit messy when it runs out the bleed holes but that is a worthy compromise for knowing that its getting into those difficult spots. we use a lot of lanolin grease at work now building power lines, both as corosion protection and as an electrical connection aid.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch `10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim. `04 BA RTV tray back, Red, V8 auto, `04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim. `03 BA XLS ute . Acid Rush, factory lpg, auto, `48 TEA20 Grey Ferguson, `62 Willys 6-230 , 4x4 light truck `04 Yamaha TTR 250 |
Hey there, i had an older 4wd for 8 years prior to finding my toy, the 4wd had small amounts of rust in it when i got it so had it repaired/resprayed and installed a product called RUST STOP. They use sacrificial anodes and some elctronic wizardry, anyways never ever had any rust return or show up and believe me I WAS SURPRISED that it worked, but it really did.
Grab one from supercheap for cheap insurance. http://www.ruststoponline.com/index....=119&Itemid=77 |
Great stuff Lanotec
I have been using it for about 5 years and it is great. I sprayed my boat trailer with it on the first day, I use my boat every week end and it still looks perfect. I work in the electrical supply industry, we spray everything with it and it makes life very easy. The grease is also great stuff |
#11 | |||
Sorry 'bout that...not much help really...
#12 | |||
Performance moderator
![]() Join Date: Feb 2005
#13 | ||
Off tap Truckie
I have used it on my Mk1 Gt years ago when it cam out. A mate got a tin for free from a rep. 10years later it is good still. But check out other product out now and they may have inproved. Also my T3 has lanotec in it too now
T3 TS50 Brembo's,AFR 185,Platuim Rockers,Haltech,MSD,Custom exhaust
![]() ![]() 1968 KC Bedford 1970 Mk1 Escort GT 1980 Mack Superliner 120t: Project Puppy Dog! AU2 XLS Cab Chassis, 5ltr, T3 Kit, Speedy Envy's 19x8.5 |
#14 | ||
When I had my gun shop, the trawler operators used it to stop their rifles and handguns rusting at sea. It worked extremely well, in fact it would preveny rust on blued guns while "stainless steel" ones that were untreated started to spot.
