Old 19-04-2009, 10:02 PM   #1
Lukeyson
Right out sideways
Lukeyson's Avatar
Default info needed : Higher stall converter for my AU XR8
ok i am wondering if a 2200-2500rpm stall converter for my AU XR8 is what i am after. I just find this car has always been a slouch off the line, and i mentioned it last time when i got the auto serviced, and he said maybe a higher stall will make it feel a little more lively.
For now the car is basically stock, just a full exhaust sys and CAI done, with future plans of alloy heads & cam.
Any input would be appreciated......
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 10:19 PM   #2
StealthAu
Diff gears.
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 11:14 PM   #3
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
st0ck stall speed is 2200-2400rpm, mine standard fact0ry stalls t0 2500rpm as have many 0thers i have been in.
Diff gears 0r a tune will help with standing start take 0ff's.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 11:22 PM   #4
Lukeyson
Right out sideways
Lukeyson's Avatar
thanks for the info there guys, with diff gears i do a few hwy km's each day to and from work, i presume if i was to get 3.73:1 gears it would prob rev at about 2200+rpm @ 100kph ??
not too concerned with economy really, but i wouldnt think it would increase a great deal?
Old 20-04-2009, 09:19 AM   #5
RG
Back to Le Frenchy
RG's Avatar
I'd go 3.9's and no it won't increase fuel consumption too greatly.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 10:04 AM   #6
MADED-6
MADED.6
MADED-6's Avatar
yeah i have 3.9's in mine and when it was auto it would sit at about 22-2300 at 100 but ur speedo will be out about 15-20km mine was out 20 now that its manual its out by 15 as i have the 3.45 cog on the speedo drive.
i dont think there is really any fix for this except a jaycar speedo corrector which can play havoc with ur cruise control.
but yeah i have a 3000rpm stall and the 3.9's and i wouldnt have changed (except a smaller stally maybe 25-2800 as mine used to go to about 3500 and sometimes even 4000) it but then i wanted manual.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 11:01 AM   #7
ayeyew
Teh Baest
ayeyew's Avatar
cheers josh.
I've been thinking about 3.9's myself... With regards to the speedo, if you run it in diagnostic mode with the digital speedo, would that still be out by the same margin? or would the digital speedo be correct?
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 01:00 PM   #8
Dauphin
Irregular member
Dauphin's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Endless work keeping the AU.com.au web site happening
I was told that the AU gets its speed from the ABS sensor so changing diffs doesn't affect it like in the past. Is that right?
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny
My hovercraft is full of eels!
Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971).
Dauphin is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 03:27 PM   #9
MADED-6
MADED.6
MADED-6's Avatar
well series 2-3 may be different but series 1 is diffenitely off the trans and im prety sure but not 100% that the othersd are aswell the ba's get theres off a digital reading from the gearbox so they can be changed via a capa flasher but ours cant unfortunately.
cheers josh.
TUFAU-8
Get Stroked.
Old 20-04-2009, 03:39 PM   #10
RG
Back to Le Frenchy
RG's Avatar
No it isn't mate, same speedo gear as the rest. I used a T3 one in mine, calibrated for 3.45's and 18" wheels.
Old 20-04-2009, 04:20 PM   #11
bellamy
be careful with high stalls only takes a little bit and it turns from a good launch to smoke and a squeal which these days is an offence which can have your car impounded.
bellamy is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 08:14 PM   #12
Windsor220
Now Fordless
Windsor220's Avatar
Anyone know what sort of coin we would be looking at to get 3.9 gears fitted in an IRS diff?
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 08:36 PM   #13
RG
Back to Le Frenchy
RG's Avatar
About $1600 with new bits.
Old 20-04-2009, 08:50 PM   #14
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Go the gears.
Unless you plan on raising your powerband, raising your stall speed is a waste of the Windsor's natural low down grunt.
If you bolted a set of AFR's, a nice Comp cam and CAI/Exhaust on the other hand..... :
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 08:55 PM   #15
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Yep i'd definately just go with diff gears (3.9:1) for now.
Once/if you get the heads and cam etc done, then you may want to get a stall to suit.
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 10:44 PM   #16
StealthAu
Nope, no magic involved in the digital read out, still gets its numbers from the speedo drive in the gearbox.
Old 20-04-2009, 10:45 PM   #17
StealthAu
B-series, not AU's.
Old 20-04-2009, 10:49 PM   #18
StealthAu
And XR8Fella, one bit of advice, ignore everyone here. Go all out and get a set of 4.11's, I got a set of 3.9's around a year ago and as soon as I had driven it decided I'd swap them over for 4.11's.
Old 21-04-2009, 12:48 AM   #19
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
If you have a flash tune box you can get your local tuner to recalibrate your speedo
apparently.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 05:59 PM   #20
MADED-6
MADED.6
MADED-6's Avatar
as said thats only ba u cant do that with au's im pretty sure.
cheers josh.
TUFAU-8
Get Stroked.
Old 21-04-2009, 06:01 PM   #21
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
So once you get a diff gear change how do you recalibrate the speedo?
I personally have been using navman and planned to get this corrected with a tune.
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 06:21 PM   #22
DW260
DW260's Avatar
My diff gears are getting replaced next week with some 3.9's and got a tentative quote for $1350. That includes a rebuilt LSD, but knowing my luck of late, the engine will probably detonate as gets driven on the hoist...
Anyway... All the tuners I have spoken to tell me the speedo can be corrected with a tune. They were also talking about that in relation to the new XCAL equipment, so maybe the software is different??
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 06:40 PM   #23
StealthAu
Nope, doesn't work unfortunetly. Speedo is driven directly from the electronic speedo driver or whaterver you like to call it, then the signal is passed onto the ecu. The only way to correct it is with a speedo corrector (jaycar item). Then the signal onforwarded to the ecu needs to be corrected either with another of these jaycar items (bringing the signal back to the same level) or with an edit.
Old 21-04-2009, 07:07 PM   #24
Cam
Stroking it...
Cam's Avatar
Seems strange that the edits cant calibrate the speedo, I have an old chiptorque HP5C chip that allowed by speedo to be corrected when I put in the 3.7's!
I cant believe the edit cant incorporate something the jaycar speedo corrector does in a small kit???
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 21-04-2009, 07:17 PM   #25
StealthAu
Strange, going off the wiring it looked like it wouldn't be possible, was also advised this by a tuner, but if you were able to correct the speedo with only a chip (didn't change the speedo driver gear?) then thats a different story.
If thats the case maybe it is different from series 1 to series 2&3?
