Old 20-04-2009, 04:23 PM   #1
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Default AU I intermitent idle issues
I'm having some intermittent idle issues on my Series 1 Falcon.
When first stated on the morning the car runs fine for a while.
Then the idle starts do drop and recover. Power is reduced. This happens when its in N or P or Drive.
Air filter is clean. Checked all the piping to the bbm and it all looks clean as well.
Put in half a bottle of injector cleaner about 100ks ago and it appears to behave a bit.
Anyone have any ideas?
I have a spare MAF lying around.. Maybe i should try changing it?
Thanks./...
Curent Rides:
-NC Fairlane Ghia 3.9L
-XC RallyPack Ute 5.8L
-AU Falcon Wagon 4.0L Still Stock
-80 Series LandCruiser 4.5 LPG
NC_Lane is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2009, 05:27 PM   #2
JC
JC's Avatar
Thanks./...
The MAF won't do much good - the 6s don't have one (they do have a TMAP sensor though).
If it's changing when warm, then I would say it is more likely to be O2 sensors, but you could change the TMAP first (it's under the TB on the AUs, not on the firewall like the E series ones were)
Ford Performance Club ACT
Old 20-04-2009, 05:30 PM   #3
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Thanks.
Where abouts are the 02 sensors in the AUs? dont have a manual for one :(
Curent Rides:
Old 20-04-2009, 05:32 PM   #4
JC
JC's Avatar
Thanks.
Same as every other car - screwed into the exhaust manifold, sort of down near the cat (there is only one on the I6).
Also, have you tried cleaning the ISC valve? It's part of the TB. GK has a good write up on how to clean it.
Old 20-04-2009, 06:14 PM   #5
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Thanks
Curent Rides:
Old 23-04-2009, 10:11 AM   #6
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Cleaned out the ICS and the TB. No Luck. After that I tired removing the plug for the ICS. Car starts and stops imediately.. Isnt iy supposed to stay on??
Curent Rides:
Old 23-04-2009, 10:11 AM   #7
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Also the TB appears to be completely closed when the car is off.
Curent Rides:
Old 23-04-2009, 10:27 AM   #8
JC
JC's Avatar
Follow this link to find out more about the IAC/ISC. Bacially, disconnect, and adjust the screw until it idles, then reconnect and you should be good to go.
http://www.fordforums.com.au/showthr...ighlight=Valve
Old 23-04-2009, 10:37 AM   #9
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Thanks Mate. will gibe it a go tomorrow..
Curent Rides:
Old 27-04-2009, 09:54 AM   #10
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Adjusted the idle still the same issue. doesnt make a difference if the plug is disconnected either.. Coud it be a fuel pump or should i change the Oxy sensor first?
Curent Rides:
Old 27-04-2009, 09:57 AM   #11
JC
JC's Avatar
If disconnecting the ISC doesn't make a difference, then I'd say that's your problem. If you have amate with the same car, see if you can do a swap, or source one from the wreckers.
Old 27-04-2009, 10:22 AM   #12
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Sorry Just clarifying When the ICS is connected again the RPM goes up to abt 1000. Doesnt make a difference on the idle issue,,,,
Got a spare at home (used) Do you need any speical sealer or gasket pit in if im changing it?
Curent Rides:
Old 27-04-2009, 11:47 AM   #13
JC
JC's Avatar
You should be able to pull it off and put the other one one using the same gasket.
But if it works as you've described, then I doubt it's the issue. Really sounds like an air leak somewhere. Have you checked the inlet manifold to head bolts? They have a tendency to work loose.
Old 27-04-2009, 12:14 PM   #14
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Nope.. Will check those.. Thanks
Curent Rides:
Old 27-04-2009, 01:32 PM   #15
JC
JC's Avatar
No worries - as you may be able to tell, diagnosing and fixing an idle issue over the internet is hard to do; it's a process of elimination, unfortunately.
Old 27-04-2009, 07:17 PM   #16
StealthAu
Thanks./...
I've had the same issue for quite some time now myself. I still don't know what fixes it but can advise what hasn't
New spark plugs
new leads
new o2 sensor
injector cleaner
cleaning the throttle body
air filter
oil/oil filter/fuel filter
new exhuast (inc cat)
new coilpack
new injectors
ecu retune
tighten manifold
new (second hand) engine/manifold/throttle body/icv/map
new icv
new battery
So what is left that could be causing this issue? Fuel pump comes to mind but I find unlikely as it seems to hold up on at peak power with 10psi of boost, other thing that has come to mind is a bad earth, but then why would it only happen on rare occasions at idle?
I've decided the issue is the car is possessed, only fix is a replacement (or exorcism)
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2009, 02:00 PM   #17
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
New spark plugs
new leads
new o2 sensor
injector cleaner
air filter
new coilpack
new injectors
ecu retune
tighten manifold
new icv
new battery
did you wack in a new engine as well
Curent Rides:
Old 29-04-2009, 02:10 PM   #18
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Can 02 sensors be swapped between cars with out issues?
Ihave 2 series 1 AUs so i can try that. Is there any special sealer or somethign i need to use if im to do this?
Curent Rides:
Old 29-04-2009, 05:40 PM   #19
JC
JC's Avatar
Yes, you can swap them around without issue; I'd use some anti seize on the threads so you can get them back out. If you don't have any, then when you do them up, don't over tighten them.
O2 sensors don't kick in until the car is warm so maybe this is your issue.
Old 29-04-2009, 08:02 PM   #20
scorpio39
I suffered with the same problem for years on a dual fuel.
Changed plugs, oxy sensor, tightened inlet manifold bolts without sucess.
Then I came accross a friends petrol Au with a similar problem.
On examination I found both engines had leaked coolant from the thermostat housing onto the manifold gasket thus causing a deterioration , above and below.
Using a small wire brush I removed the gunk and completely sealed the area with silicon.
To date the idle is fine on both fuels !!!
scorpio39 is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2009, 10:37 PM   #21
StealthAu
Re-read my list.....engine is towards the bottom of it.
Old 01-05-2009, 11:42 AM   #22
NC_Lane
NC Fairlane Ghia
NC_Lane's Avatar
Ok this apperas to be sorted now..
Decided on wednesday night to give it a good once over.
Was checking the plugs and one of the leads just snapped in 2.
Replaced all the leads and plugs yeterday and it appers to be ok now..
Thanks for all you help
Curent Rides:
Old 01-05-2009, 01:17 PM   #23
JC
JC's Avatar
Quite often it's the "simple" things like this!
