Old 05-05-2009, 07:58 PM   #1
LukeyST
ST fan
LukeyST's Avatar
Default AUIII XR6 VCT, hard starting, high idle, maybe running a little rough?
Hey everyone,
Got a few concerns with the ST, and I want to get them sorted.
a) Ever since i bought her (in January) shes tended to cough a bit when starting. Like it will crank over ok, but once it starts the revs fluctuate and it dies right down, then she will generally return to idle and be fine, but sometimes it will stall completely : Sometimes she'll start no worries at all, i can't pick any consistencies but :
b) What rpm should it be idling at? Upon starting, and returning to idle it will sit at about 900-1000rpm, but after driving for a while and returning to idle it will sit at about 850-900rpm. Maybe the VCT's just idle higher? Not sure. I thought the idle should be about 700rpm.
c) Up high in the revs under acceleration, it seems a bit course, but i think im just used to my EL, which had the cam timing and ignition timing advanced which seemed to make it a bit coarse low in the revs but smooth as silk from 4500-6000rpm. Just thought i'd ask the question, as it might be related to a) and b).
So was basically wondering if anyone knows what causes such issues, i've been thinking coil pack, injectors, crank angle sensor, oxygen sensor, idle sensor?? Dunno. I'd just like to get a more definite answer/advice before i start buying parts only to find it doesn't change anything.
The car is an AUIII XR6 VCT ST. Manual, 130,000kms. Has x-force extractors but stock cat and system. I adapted a pod filter into the box and i've got a hole cut in the front of the airbox. I recently changed plugs and leads, so confident its not that. Also, i only ever fill it with BP ultimate, not that that should effect it.
I think that 'bout covers it _2:
Cheers.
2013 Focus ST in TANGERINE SCREAM
2003 Focus Zetec in COLORADO RED
LukeyST is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 09:02 PM   #2
V8falcons
V8falcons's Avatar
gday looks like you have a nice car. from your avatar
Any way check your inlet manifold for leaks ,I replaced mine on the weekend,as it was ideling high and running rough from a leak(broken gasket and loose inlet manifold bolts) on the no 3 runner.
she's like brand new now.
$13.95 for the gasket
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2009, 09:26 PM   #3
LukeyST
ST fan
LukeyST's Avatar
Ok thats pretty bad if yours was actually damaged mate. I'll check mine tomorrow afternoon. Its good that you reminded me, cause I always used to check the bolts on the EL, but have yet to on the XR.
Cheers.
