Old 10-06-2009, 07:55 PM   #1
ivanhatescars
Default another door lock saga
The doors on my 99 au sedan won't lock,the interior light and the door open warning indicator on the dash stay on even though all doors are shut. I am wondering if a door switch is at fault and this is not allowing the doors to be locked.The main problem is that the doors can't be locked manually,the drivers' door is the only one with a manual lock.Thanks for any help, Ivan
ivanhatescars is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2009, 07:57 AM   #2
whiskers
gone fishing
whiskers's Avatar
Hi Ivan,
there seem to be a few threads going at the moment about this subject, have a look through them and you should be able to pin it down.
Or do a search about doors not locking and it should bring you heaps of info.
cheers
Whiskers
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2009, 01:53 PM   #3
GeoNazi
My car won't lock either the door lock fuse blows,, look at your fuse man.
GeoNazi is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2009, 09:53 PM   #4
mik
mik's Avatar
just wondering ....does it sound like its even trying to activate the lock solenoids?
Old 12-06-2009, 05:30 PM   #5
ivanhatescars
hey guys thanks for your help,solved the problem and yes i did spend hours looking through previous threads and nothing was similar. The problem was down to the door lock not engaging enough when closed, but at the same time secured but not fully closed. Adjusting the door latch a bit fixed the problem. Thanks, Ivan .
Old 13-06-2009, 01:21 AM   #6
mik
mik's Avatar
well done.
Old 13-06-2009, 09:18 AM   #7
whiskers
gone fishing
whiskers's Avatar
glad you got it sorted out Ivan it makes you feel good inside when you get it fixed by yourself.
cheers
Whiskers
