14-11-2008, 08:20 PM | #31 | |||
Focus TDCi
i want to set up a CAI with a enclosed K&N pod filter. is the intake pipe the same size on a petrol to a diesel? |
15-11-2008, 09:25 AM | #32 | |||
yum
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
15-11-2008, 10:18 AM | #33 | |||
Focus TDCi
15-11-2008, 12:11 PM | #34 | ||
I would assume that if there is sufficient shielding for the filter then the amount of warm air ingested by the engine would be kept at a minimum, the intercooler does cool only slightly, however if the air through the filter is warmer than normal, more than likely you would loose performance... diesels seem to be funny when it comes to air.... Im not too sure how the DuraTorq engines manage this (havent looked into schematics and diagrams) but the standard airbox, does insulate from heat better than a pod would, but if you have to go for a pod, find some ally sheeting that you can cut and bend into shape and find some sealing to run on the edges to prevent cutting of anything from the edge. I would also assume a means of securing the pod aswell for the legalities (different under each state)... but to my understanding a pod on a diesel will not have a huge difference as is expect when it comes to the petrols variants.
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL Check out 819FLY!! |
16-11-2008, 02:22 PM | #35 | ||
Badly Focused
To my mind air is air, and the more and colder it is the better. If they use a similar intake setup to the petrol (airbox and a resonator), try pulling the resonator off and running a CAI pipe to it. I'm pretty sure that (as far as performance is concerned) this is at least as good as a podfilter stuck low in the guard.
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels 16.045...0.05 of a second! I wanted a 15sec pass! 93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE! *Maybe we don't try putting holes in things that sink, yeah?* |
14-06-2009, 12:32 AM | #36 | ||
Focus & Territory TDCi
can anyone confirm that the E-2993 k&n filter is the correct filter for a 2008 TDCi Focus??
http://www.knfilters.com/search/prod...px?Prod=E-2993 |
