Old 08-07-2009, 07:21 PM   #1
HLC
Audi S3
Default Doing the rear springs/shocks tomorrow/friday
Hey guys,
i plan on doing the rear springs/shocks over the next couple of days.
now i helped do them last time, but this time ill be all on my lonesome.
so i just wanted to run it through, is it as easy as just jacking the car up, sticking it on stands, then dropping the top shock mounts and everything falls out???
or do i undo the bottom mounts first?
ill have a look in the workshop manual but just incase someone already knew a quicker/better way to do it to save a bit of hassle if i eff it up!
cheers
Old 08-07-2009, 11:16 PM   #2
bodes-sh
come on man, GK did a wicked writeup on this....
lol, in all seriousness, you pretty much have it covered i reckon with what you have said above. i'd undo bottom last as you can grab the shock as you undo it. if you undo top first you can lower the whole lot down together
Old 09-07-2009, 08:29 AM   #3
brad`
The Monty
brad`'s Avatar
what springs and shocks ur gong for HLC?
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 10:19 AM   #4
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Is it IRS? If it is, I did mine recently and as long as you have the lowered springs in the whole lot should fall out once you undo the top shock nut and lower the jack holding the hub up. The stock springs are too long to do it this way so you'd need spring compressors and remove the whole lot, top shock mount included, and dismantle the strut out of the car. I bought a pnumatic ratchet to do mine and had the second side completed and the car back on it's wheels in less than 15 minutes. ( First side took 45 minutes till I worked out the quick way to do it.) The trickiest part is getting the top of the shock piston shaft at the right angle to slip back up through the hole in the mount.
Bushbasher
MINE- AUII Forte
Old 10-07-2009, 05:12 PM   #5
HLC
Audi S3
Well i just printed out the workshop manual page and took it to the garage with me.
i didnt even read it.
the hardest part of the whole excercise was getting the thing onto jackstands using the bloody scissor jack HAHAHA and thats only because the jack stands i have were more designed for 4WD's rather than normal cars, these things are over a foot tall without even extending/raising them.
but yeah i jacked it up, undid the tops, let it down, undid the bottom shock mounts and let the old shocks just fall out, who cares they were rooted. and yeah.
took about 2 hours which i thought was reasonable.
got SSL's + short throw shocks in the rear now. ill do the front next week with SSL's too hopefully if i order the springs/shocks soon and get some spring compressors.
Old 10-07-2009, 09:25 PM   #6
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
pics!!!
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2009, 10:15 PM   #7
JoesAu
JoesAu's Avatar
got pics and wat brand shocks u get?
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 12:28 PM   #8
HLC
Audi S3
pics when i wash the car, its been raining so its brown lol
Selby springs and ultima shocks lol ebay special! 240 bucks! haha
Old 11-07-2009, 01:13 PM   #9
Stav
Smile
Stav's Avatar
Thats a steal mate ..awesome
Old 11-07-2009, 03:28 PM   #10
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Clean car???
So you are never going to take any pics then ???
:hihi:
UK
