Old 09-07-2009, 03:07 AM   #1
Linz
*SILVER SERVICE PILOT*
Tech Writer: Recognition for the technical writers of AFF - Issue reason: For his technical submissions. Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with good, solid advice.
Default Low idle after battery removed/replaced.
Hey all, had to change the drivers side headlight bulb last night so had to remove/replace the battery so I could get to the thing (big hands).
Anywhooo, when driving it today, when you put it into reverse or drive, the idle speed drops right down to almost stall speed and then picks up again. The car has been driven about 40 kms since the battery was out but it still has the low idle after changing gears. I've done the disconnect battery thing heaps of times in different Falcons (AU, BA's etc.) with no problems like this afterwards : ...anyone have some clues as to what is wrong??
Thanks in advance...Linz.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271
2006 Lightning Strike BF Fairlane Ghia...HIS
2024 Titan Grey Hyundai Tucson Highlander...HERS
Linz is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 04:58 AM   #2
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
Pretty normal, give it a few days for the ecu to re-learn. Or to speed the process up a bit, let it sit there idling in park for about 10mins, the idle should improve as time passes, as the ecu is relearning. Then put it in drive with your foot on the brake and sit there for 10mins again. This works for me, see if it works for you.
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2009, 08:22 AM   #3
whiskers
gone fishing
whiskers's Avatar
or you could try this to "re learn the ecu" it's quicker
http://www.aufalcon.com/cgi-bin/inde...f=techdocs/ECU
Whiskers
Old 09-07-2009, 09:01 AM   #4
bodes-sh
might be worth cleaning out the throttle body and isc too if you haven't recently. seems to help a bit
Old 09-07-2009, 11:12 AM   #5
Linz
Thanks a lot guys...I'll give it a go :
BUILD THREAD
Old 10-07-2009, 04:25 PM   #6
gtfpv
GT
gtfpv's Avatar
was the car tuned in the past ?
gtfpv is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2009, 04:33 PM   #7
The Monty
Just slidin'
The Monty's Avatar
Just drive it around for a day or two, it will be fine. Its just that the ECU has reset. Nothing wrong with it, just give it time.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 10-07-2009, 04:44 PM   #8
GK
Walking with God
GK's Avatar
Question
Originally Posted by linz
Did this last night but still no good. I'm just wondering if the battery may be on it's last legs, getting it checked out this afternoon.
Did the battery check out okay, or was it cactus?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 10-07-2009, 08:55 PM   #9
mik
mik's Avatar
i`ve disconnected my battery a few times now to do variouse jobs and it seems to run exactly the same after reconnected, am i just lucky? are the battery posts/terminals clean?
Old 10-07-2009, 09:28 PM   #10
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
Depends on how long the battery is disconnected for - give it about 45 mins to an hour....then the ECU has definately reset itself.......
I did the same thing a while ago - took a couple of days driving (about 100kms) and everything was fine after...........felt like it had a little more grunt as well!!!
Probably should do it again soon I reckon!
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 08:30 AM   #11
Linz
BUILD THREAD
Old 11-07-2009, 09:25 AM   #12
Stav
Smile
Stav's Avatar
Yes the ecu has many startup maps which tend to go rich on battery reset and the idle speed is also altered.This is due to the fact that the ecu has adjusted over time to wear and tear in the cars engine to keep it good.Unfortunately it does not hold the memory on battery reset and starts from base maps hence the problems.Id recomend resetting it a few times until it finally comes good.Then do not reset it again
Old 11-07-2009, 05:42 PM   #13
Linz
Thanks again for the replies everyone...battery tested up fine, the car is gradually getting a bit better, it's ok with no a/c running but as soon as you turn it back on, it starts stalling or very low idle so we'll just keep driving it over the next few days until it comes good. Don't know whether it's BS or not, but Southside Fraud service guy reckons the ISC is a bit of a problem sometimes on the AU's after battery disconnection...time will tell.
It's strange that this should happen as I've disconnected batteries lots of times without a backup power source on EB's, EF's, EL's, AU's and BA's without the hint of a problem...I guess there's a first time for everything.
P.S. Guess what I bought today? Yes, that's right...a backup power supply :hihi:
BUILD THREAD
Old 11-07-2009, 06:30 PM   #14
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Please show & tell. I'm scared to disconnect my batt to fit cruise cos so many ppl have problems.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2009, 09:49 PM   #15
Linz
It's a very simple thing that I got from Autobarn...a cigarette lighter plug with a couple of leads attached and a 9v battery connector on the end. Clip on a new 9v battery and fit it into the power source socket and it's SUPPOSED to hold memory. Not sure for how long, but it'd be good enough to change the likes of headlight bulbs or fit a new car battery.
BUILD THREAD
