Old 31-07-2009, 06:00 PM   #1
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
Default 6x9 install problems HELP PLEASE
hey guys im having trouble trying to install my 6x9's are there any pods i can buy that suit the rear pastle shelf as the cheapie plastic ones are sh#t and look hmmmmm.
or is there anyone that has made custom ones thats willing to share?
any help is appreciated.
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2009, 06:19 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
screw them in from underneath
Old 31-07-2009, 10:42 PM   #3
Mont5.0
Mont5.0's Avatar
they wont fit the factory holes with out widening them or putting massive spacers under. I fitted my 6x9's with a small trim to the factory holes, and some 3/4 inch MDF spacers.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2009, 10:43 PM   #4
Mont5.0
Mont5.0's Avatar
wont work!!
Old 31-07-2009, 10:55 PM   #5
au11futura
au11futura's Avatar
yeh mine are preaty beafy 6x9's the magnet is huge, but the plastic spaces are to tall. i think ill try the mdf trick but i afraide illhave to mould them by hand as the pastle shelfs are bloody awkward to work with.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 31-07-2009, 10:55 PM   #6
Travisty FTT
'06 Ford Territory Turbo
Travisty FTT's Avatar
Originally Posted by Mont5.0
wont work!!
Worked fine from underneath on mine without modification.
Travisty FTT is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2009, 11:26 PM   #7
au11futura
au11futura's Avatar
well ill get onto it tomorrow and let you guys know but in all honesty i would love to mount them on top not under.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 31-07-2009, 11:28 PM   #8
au11futura
au11futura's Avatar
just for image sake here they are.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 01-08-2009, 12:04 AM   #9
xygt01
XY GT (ROD)
xygt01's Avatar
mount them under still i the original holes that way you still have the factory grill on the shelf
xygt01 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2009, 08:19 AM   #10
JC
JC's Avatar
Or buy some 5x7s - they fit with no spacers, no cutting, and sound just as good; rear speakers are really only for "fill" anyway, so buy a reasonably priced set for the rear, and buy a good set of splits for the front.
Ford Performance Club ACT
Old 01-08-2009, 08:57 AM   #11
Mont5.0
Mont5.0's Avatar
wont work!!
this is going to depend on the 6 x 9 its self. mine would not fit from underneath, others may.
Old 01-08-2009, 09:36 AM   #12
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
Using 10mm MDF we cut out spacer that 'just' gave enough meat for the screws to go through as well as the the shelf:
The only downside to this is that you do get about a 5-7mm gap from the speaker to the parcel shelf, but unless you get in the boot its not noticeable.
Just thought I'd give you some ideas
Edit: After installing these I decided to screw putting the 6" speakers I had in the front and invest in a good set of 5x7's, so much less work and the sound is just as good if not better.
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2009, 03:15 PM   #13
au11futura
au11futura's Avatar
would that space effect the sound quality?
but ill see im onto it now so ill keep you updated.
thank guys.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 01-08-2009, 08:32 PM   #14
au11futura
au11futura's Avatar
ok i fitted them heres what i did thanks to kenwood supplied parts.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 01-08-2009, 08:32 PM   #15
au11futura
au11futura's Avatar
thanks for the help guys
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 02-08-2009, 12:06 AM   #16
grandpa_spec_F6
AFF Whore
just an extra bit of info, if you're running a sub (which I am) I found that running the 6x9's though a high-pass filter really helped the overall sound as they tend to create a bass note of their own which interferes with the subs note.
The gap does let a 'tad' more bass into the cabin but im no audiophile so it suffices for my purposes. Your install looks good, you've got the majority of the surface area of the 6x9's exposed though the factory hole which means that you should get a fairly good sound.
Old 02-08-2009, 10:31 PM   #17
au11futura
au11futura's Avatar
yeh mate i used to run the same 6x9's for comps and off the amp not the deck these kenwoods i found come closeto my sub for bass but in my ed the sound was different ill see soon how it goes with them in the AU i was distracted today and didn't get around to it.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
