03-08-2009, 12:11 PM | #1 | ||
Resident AFF detailer
1) Is there any one single oil filter for 6cyl AU's that is better than the rest? Or are they all essentially the same?
2) I've got some of the FUCHS Titan CFX 10w-30 oil to go in at my next oil change - have heard nothing but good things about this oil. I also have a bottle of the Lucas Heavy Duty Oil Stabiliser as well. Would the oil stabiliser offset any benefits of the Fuchs oil, given that there would be 1L of oil stabiliser and 4.5L of oil in there, as opposed to 5.5L of oil? Or do the benefits of the oil stabiliser just add to the benefits of the Fuchs oil?? Your thoughts guys???
03-08-2009, 12:11 PM | #2 | ||
oops! Can a mod please move this to the general AUFalcon.com section!!!!
03-08-2009, 12:39 PM | #3 | ||
Barra Turbo > V8
Done and done mate
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
03-08-2009, 01:09 PM | #4 | ||
i use, penrite oil, and yes there is only one oil filter, what you need is a z9 oil filter for a i6 cheers
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
03-08-2009, 01:14 PM | #5 | |||
Back to Le Frenchy
Purolator is all I ever use mate, you could always get a K&N if you feel like spending the big dollars.
03-08-2009, 03:53 PM | #6 | ||
Flairs - Truckers Delight
PureOne Purolator is the best
however a Ryco Z9 will do. But the K&N ones are ok too, especially as they have a nut on the end
2006-2016: Regency Red 2000 AUII Ford Falcon Forte Automatic Sedan Tickford LPG "Millennium Falcon" Last edited by Mr Hardware; 03-08-2009 at 04:09 PM. |
04-08-2009, 12:13 AM | #7 | |||
anybody got any thoughts on the 2nd question I asked?
04-08-2009, 06:49 AM | #8 | ||
This site may help answer your question
Click Here By the way, does anyone know where to buy the Puralator filters in Melbourne. I've been trying to track them down but no one seems to stock them. |
04-08-2009, 08:19 AM | #9 | ||||
Back to Le Frenchy
04-08-2009, 09:24 AM | #10 | |||
Seems the Lucas stuff may not be all that it seems to be!!!! Does anyone else know of similar links with evidence for or against the product? I only ask because at a recent service a few months back, the mechanic waxed lyrical about the Lucas stabiliser, how good a product it was etc etc!!!!
04-08-2009, 11:05 AM | #11 | ||
I think blueoval put a bottle in at his last oil change, will be interesting to get his thoughts......
04-08-2009, 01:01 PM | #12 | ||
Have done a fair bit of forum-trolling the last couple of hours about the lucas oil stabiliser - for every person that brings up that link (and there are a lot who use that link as the reason for not using it), there is somebody who swears by the product and says how it's helped their car in some way - a lot of mechanics as well giving the thumbs up (and a lot giving thumbs down).
The general consensus (for those against) seems to be that the oil companies spend literally billions of $$$ on R&D, if the lucas stuff worked, they would already have the ingredients in the oil you buy off the shelf!! Is there anybody here who can qualify these opinions with regards specifically to AU Falcons???? Any mechanics among our ranks????
04-08-2009, 02:21 PM | #13 | ||
04-08-2009, 03:08 PM | #14 | |||
Critical Thinker
I did put a bottle of this stabiliser in a few oil changes back. I have mixed feelings about what it did to my motor. In some ways when I put the OS along with some 20w/50 in, it quietened things down a bit, but found the noise came back after a few hundred k's. I attribute this to the oil being too thick for the age of the motor. At the time my motor did about 130,000km. The next oil change, all I did was an oil flush, and I used 10w/40 Nulon Hi-Tech Fast Flowing Full Synthetic Oil and found that made the engine heaps quieter than with the stabilser. Not that the stabiliser was good, it probably is with engines that have done well over 200-300,000km. I just found it was too thick and I could hear that it wasnt getting into all the oil galleries like oil should. Ever since then, I have been doing a engine flush at every major oil change and used the Nulon Hi Tech with a K&N oil filter and its been great ever since. Of course, others opinions of this may vary, but I recommend experimenting on what oil is best for you. As far as the oil filter is concerned, I was using Ryco/Purolator as well as cooper filters. They did fine for when my engine was NA. But being forced, I felt it was time to make sure I got the best I could. My brother in law had used a K&N filter on his EF every 5000km when he did minor and major services and he said he found the filter collected more contaminants/particles than when using a cheaper brand. Plus the nut on the end of the filter was dam handy. Now Im not certain if his findings were legit, but I did see his last oil change he did with this filter, and the old oil came out a with a bit more color in it than jet black like old oil tends to be. Its up to you what you use, but I would say that if your changing filters and doing oil changes regularly on an NA car, you wouldnt have issues with a Z9 X brand filter. Check out this link for the K&N oil filter specs . Check out this link for Ryco Oil filter specs Check out this link to Purolator Oil Filter specs All the above filters claim they are the best, but I would just get what you think will do the job efficiently. It will come down to if you care what you put in your motor vs CBF spending the cash so what evers cheapest decisions.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
04-08-2009, 03:45 PM | #15 | ||
thanks Shav, great feedback as usual!!!
Think I'll take it back and just go with the Fuchs Oil and see what happens!!!!
04-08-2009, 04:15 PM | #16 | |||
Critical Thinker
Chances are you wont notice bugger all, but if your attune to your car and how it behaves, you may notice a few subtleties in the engines behavior with various oil brands/types/grades. On that note, Fuch's is a decent brand.
04-08-2009, 05:35 PM | #17 | ||
Walking with God
Another option for those wanting to collect all the shavings they can could also consider a magnetic sump plug.
I have one in both my AUs. GK
04-08-2009, 06:57 PM | #18 | ||
Critical Thinker
where do you get those from George?
04-08-2009, 07:42 PM | #19 | |||
04-08-2009, 07:46 PM | #20 | |||
Critical Thinker
04-08-2009, 08:22 PM | #21 | ||
so if it's making the noise that's bad I'm assuming?
04-08-2009, 08:53 PM | #22 | |||
If you choose a brand name oil of the correct weight for your vehicle, and change it at regular intervals, you be fine. As blueoval said, you have to know how your motor behaves pretty well to spot the difference between the different oils. Oh, and for what is worth, my parents have their cars service at their local mechanics (AU series I forte and an AU series III e-gas). Their mechanic uses HPR 5 for the AU series 1 and HPR Gas 10. Cars have 150XXX for the Au series 1 and 270XXX for the Au III egasser. If you want more info on oils, check out bobistheoilguy.com. Heaps of info about oils. |
07-08-2009, 03:03 PM | #23 | ||
Hi fellas, I realise i may be in the wrong section for a BOSS question but what you are talking about in here is sorta what i wanna know, particularly the last few posts..
My BOSS is just past 150,000km now and it's time for my next oil change.. I wanna go thicker cos there is a real subtle knock when first starting up.. but i'm not sure how thick to go cos i don't wanna be starving certain narrow galleries of oil.. I dunno much about the lifters in this motor or how well they'l flow with thick oil.. anyone able to give me a pointer? ps: don't know what the current oil is, only had the car 4 months/5,000km
customer: "My car seems to be changing colour and growing wings" Ford Service: "That's normal, they all do that after about 10,000km 2009 FG XR6, Ego Paint, Darkest possible tint, Sunroof, Black Vic number plates. No performance mods. Born To Be Mild |
