Old 17-08-2009, 05:17 PM   #1
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default AU Injector Size and Fuel Reg KPA I6
Searching Google I have found that the part number for the AU Injectors is:-
Bosch 0280 155 844
And they Flow 20lbs/hr
They also have 4 pin hole which spray the fuel
Also i read somewhere else that the Bosch 0280 155 844 flow 14.3lbs/hr
And I have no idea what the Fuel Regs for the AU's are rated at - can anyone help me out?
Is there a difference between the XR Models and the Std I6 models?
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2009, 05:21 PM   #2
FreddyDUZ747
FreddyDUZ747's Avatar
Non XR6 at idle is 225kpa
XR6 is 250kpa
With reg vac hose dissconnected its 275kpa non XR6
XR6 " "300kpa
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2009, 06:32 PM   #3
Sorted
Sorted's Avatar
Sweet - thanks for that
SO whats the flow of the XR's Injectors - I assume they have more flow than the Std I6
Tuned by DYNOMOTIVE
Old 17-08-2009, 06:43 PM   #4
FreddyDUZ747
Pretty sure they are the same,they have a slightly larger flowing fuel pump though
Old 17-08-2009, 07:43 PM   #5
Sorted
Sorted's Avatar
Thanks Gilmore
On another forum
The EA thru EL ran 0280 150 790 --18.15lbs/hr 1988-1998
The AU ran 0280 155 844--14.3lbs/hr 1998-2002
That cant be right.................arrrrrrgggggggg!!
Tuned by DYNOMOTIVE
Old 19-08-2009, 10:08 AM   #6
Sorted
Sorted's Avatar
FYI Hmm smaller injector flow for an AU
Au Injectors
Part Number 0-280-155-844
Lbs/hr 14.3
Cc/min 150.3
Grams/min 108.1
Feed EV6
EF-EL Injectors
Part Number 0-280-150-736
Lbs/hr 18.25
Cc min 191.8
Grams/min 138
Feed EV1
EF-EL Injectors
Part Number 0-280-150-790
Lbs/hr 18.17
Cc min 191
Grams/min 137.4
Feed EV1
Tuned by DYNOMOTIVE
Old 19-08-2009, 01:03 PM   #7
Sorted
Sorted's Avatar
Bugger than info was wrong
Here is the correct info
0 280 155 844 - 150.2 g/min - Tested resistance was 14.5ohms which are EV6's
0 280 150 790 - 149.7 g/min - Tested resistance was 15.9ohms which are EV1's
Here is the linky to the Bosch Catalogue http://www.bosch.com.au/content/lang...linjectors.pdf
Tuned by DYNOMOTIVE
