View Poll Results: 'Power' or 'Eco' for standing start drags? | |||
Power | 34 | 60.71% | |
Economy | 5 | 8.93% | |
i use 1-2-3 (trany needs servicing soon!!!:P) | 17 | 30.36% | |
Voters: 56. You may not vote on this poll |
11-08-2005, 09:03 AM | #31 | ||
Hurry up Germany!!
thanks guys
sometimes when it is changing gears under about 40-60% throttle it will rev up higher to change gears and then clunk into the next gear. iv been told it is a ford thing, is that right? cheers
2009 WS Fiesta Zetec 5-Door
Color: Vision |
11-08-2005, 09:53 AM | #32 | ||
www.lukehimself.net
i say use power but i always go in eco coz i forget to switch
11-08-2005, 10:35 AM | #33 | |||
Low and Loud
(update your sig to include Fairmont ghia Doortrims)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
11-08-2005, 05:11 PM | #34 | ||
My auto in my leb spec EF futura holds gear at 5500rpm in Power and shifts at 5000rpm in eco.
edit- i am in saudi though i had my ef imported. does it make a diff if i'm in a nother country? |
17-08-2005, 09:36 PM | #35 | |||
No, country does not matter. Hemisphere does |
18-08-2005, 09:44 AM | #36 | ||
GOT 20'Z?
power button will not make your car faster unless u hook it up to a bottle of nos, all it does is hold the car in gear for longer, and if u cant tell when to cahane gears if u do it manually (which is what u should b doin if u dragin) you shouldnt be drivin a car at all.
one day my car will live upto its plates! out: |
18-08-2005, 09:58 AM | #37 | ||
mines alot more responsive on the highway when putting the foot down in power mode...but then proceeds to flare its *** off...hopefully a shift kit will get rid of that
18-08-2005, 01:23 PM | #38 | |||
Last warning
wish my car did though :S
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
18-08-2005, 01:30 PM | #39 | |||
Official AFF conservative
Let's also consider line pressure. Similarly to shift points, line pressure at WOT is not much different between power and econ (compared with difference in LP at lower throttle) - but it is different. So if you plan on experimenting with pwr/econ, at least fit an S5 mod so you minimise the shifting time in econ mode.
A cup half empty... but full of euphoria. |
18-08-2005, 02:35 PM | #40 | ||
my ED is a manual which i suggest to all who want to drag but in my bro's auto EA there is no real noticable difference bw power and eco at WOT
18-08-2005, 03:09 PM | #41 | ||
What differance dose it make??
18-08-2005, 03:26 PM | #42 | ||
PM me if you want
I have mine in power mode 24/7 and I use 1-2-3 as well, well with a BA shifter installed what else would I do
18-08-2005, 07:21 PM | #43 | ||
ED Fairmont
I work at a New Ford Car Dealership and looked into this with a few of the mechanics. Apparently the ECU is specifically set to a max rev cut out. All the PWR switch does is holds each gear longer, allowing more revs to be built up, with reduced pedal travel. At complete open throttle it will hold the gear to its max rev cut out regardless of whether your running in PWR or ECO. The variations in performance experienced by some of you may simply be due to a poor throttle cable/kickdown cable calibration, meaning when you think the accelarator is completely depressed, the butterfly may not be completely open, hence the additional performance when in PWR mode, because it holds the gear longer.
97 NL Tickford Fairlane Ghia
*Lowered with King Springs* *BF GT-P Rims* *Pacemaker Extractors* *2.5" High Flow Cat* *2.5" Straight through to the Tip* |
18-08-2005, 08:18 PM | #44 | ||||
