Howdy fellas,
The right side of the heater/fan speed dash dials have stopped illuminating when the headlights are on. How do I access these and what sort of bulbs etc.. do I need? cheers |
Bearded Hermit
have you tried giving it a whack? my left side of that section goes out sometimes...& a nice open palm slap gets them going again.
I would also be interested in knowing what bulbs & how to get there, i assume pull out cd & dash panels will be removed from there...are bulbs the same bulbs as in the instrument cluster? |
![]() Join Date: Aug 2005
If it is a Series 1, the globes are soldered to the circuit board. Series II and III have little globe/holders fitted. three of one size and 1 of another. They are available (II & III type) from a Ford dealer; 3 x AU2 10B765B and the other, 1 x Au2 10B765A. They are $5.80 each.
For the AUI type you will need a soldering iron and some little globes from either Jaycar or Dicksmiths and a little patience. ![]() |
#4 | |||
www.TUFFCARPARTS.com
gone fishing
follow this tutioral to get the dash out http://www.fordforums.com.au/showthread.php?t=95787
then you need to take the air con control panel out which is just under the vent I have just done mine its a series 1. I got another one from ftg posted to qld for $65 but had to take it to an auto elec to have 2 bulbs replaced as I wasn't confident enough to do the soldering I could have got the globes from repco on a serise 1 there are 3 globes that are in a socket and the rest are soldered. hope this has helped you out cheers
Cheers Whiskers |
#6 | |||
#7 | |||
All Bran = Regular Member
I'd like to swap it for a blue led. I pulled the switch apart but the globe was a tiny little thing about the size of a match head. |
Thanks for the responses guys, I'll check it out.
#9 | |||
They are only little bulbs but have a big blue bit of plastic that the sit in which makes them a wedge style fitting. I simply removed light from the wedge and soldered into place. Will try to find another set for you and post up link. Wrong colour but same thing.Clickity |
lol i gave him a call and told me he fixed it by hitting it and i was like damn you can almost fix an au with a hammer
Bearded Hermit
i was right...cool stuff, i might be new around here...but i guess i proved my knowledge & love of the AU
#12 | |||
they are fairly common so you won't have much trouble finding a led the same size |
#13 | |||
I've changed all the other cluster and switch globes (except the auto selector one) to 5mm/10mm blue leds but when I had the head light switch apart the globe looked much smaller - it's been a while but if I had to guess I'd say 3mm? I'm certainly not insisting that 99 is wrong in his assertion. Maybe it just looked smaller but is in fact a 5mm? I dunno but it's not difficult to get at so I'll revisit it in the not too distant future. |
