28-09-2009, 06:45 PM | #1 | ||
i had a service at easter time, and had a engine oil flush and a full new bottle put in, last monday ive checked the oil and has gone right done past the add sign and past the bottom line, i have no leaks what so ever, no oil puddles on the ground, and no power lost either,
does this mean im up for a rebuild or is it a simple fix,
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
28-09-2009, 07:00 PM | #2 | ||
How many KMs on the last oil change?
Did you notice it dropping before last monday? Does she burn a little oil,whats your oil cap like? |
28-09-2009, 07:00 PM | #3 | ||
Lost Boost Gained Class
mine was doing the same thing it could be 2 things your PCV Valve is full of stuff and needs replaceing its about $12 from Birsons
or it could be your rings on there way out witch in that case the moter will neeed a rebuild thank god mine was only the PCV valve id go get a new one and fit it and top the oil up and watch it iver the next 2 weeks or so Is your car Blowing Blue Smoke out of the Exhust??
2006 BF Fairmont Ghia
2001 AU Falcon |
28-09-2009, 07:08 PM | #4 | ||
unsure taking it to my ex diesel mechanic tommoro, when she is sitting at idle and i rev it no blue smoke comes out or anything like that,
found out the rumble noise which has been buggering me, thought it was conrod noise but its not, one of my lifters has collapsed and is making the rumble nosie thats 700 dollars to fix, new cam gear, new lifters, head bolts and gasket kit, labour, head gets sent away to be machined and tested, would that collapsed lifter have anything to do with engine oil use
28-09-2009, 07:10 PM | #5 | ||
gilmore,
i take my oil cap off and she is black, i think my car had about 290,000kms last service and now has done 309 000kms no power loss at all still has the guts no oil leaks on the ground at all either
28-09-2009, 07:39 PM | #6 | ||
Thats about 9000km past when it should have been done.Its burning it off.
I do mine every 5000km and when oil comes out its definetely done her job by then. Your up for another engine flush but this time drain the crap out but leave the oil filter on.Next you put some Cheap 20w50w oil in with flush additive and give her a good 15mins idling with varying revs every minute or so.Fill her back up with good oil and new filter after that. Get this done before she drops her guts. Sounds like your service schedules are a bit on the lengthy side.Does your car have the books/manual? Are you pulling our legs?lol |
28-09-2009, 08:04 PM | #7 | ||
what do you mean buy pulling legs,
the car is 10 years old, was bought from zupps holden, with under about 250 000 at the time, was used as a rep car before my parents had it and then i bought it off them, not knowing about these problems, i havent had the time or money to get the serivce done of course it has books, last serivce had rad flush and fresh engine oil put in and i was there when it was done and a new filter, it is going in soon after my mothers car to get its serivce done, i havent had the time to do it recently with the recent loss of my job and no money, how dare accuse me of pulling legs if i was i wouldnt post anything not to worry when she drops, just rebuild another engine for her with the help of parents comming to the party, so they should, sold me the car with these problems grr engine rebuild will cost about 2 grand, but while im there i might as well get some work done and a cam, then go get a tune,
28-09-2009, 08:12 PM | #8 | ||
Well the books will tell you to change oil every 10,000kms,you had a job around that time yeah?
Cant blame me for asking. |
28-09-2009, 08:20 PM | #9 | ||
anyways wont no till i get it checked tommoro will update
28-09-2009, 08:36 PM | #10 | ||||
PS: Goodluck in finding a new job!!! |
28-09-2009, 08:42 PM | #11 | ||
thanks, i have replied for 20 in the past week, nothing, no phone call no email nothing,
lol my parents did no of this they just denied it, owe well, its owned out right and i wont be getting rid of it, when it was bought form zuppz holden, went back 5 times for the right tow bar, 5 times for them to fix the window, grrr lol if it drops it guts i have a excuse to move my date for my build forward, will rebuild bottom end and get a freashen up on the head with preformace gear and a cam, thinking about the non computer cams, any one had experience with these cams before cheers
28-09-2009, 09:58 PM | #12 | ||
All engines will burn a little oil with normal operation, the mileage you have done since the last service you should expect the level to be down a bit.
Your lifter may have failed due to not changing your oil regulary, not changing it will allow it to sludge up which will block oil galleries, lifters etc and can cause rings to stick in their grooves
28-09-2009, 10:01 PM | #13 | ||
not quiet sure, i no the rockers and that are very noisy when up in the rev range, wont no till tommoro, till i find out
29-09-2009, 08:44 AM | #14 | ||
well im off today for check on car and to see whats wrong etc, will take a camera and some pics of what we find
if worse comes to worse, i will be rebuilding bottom end with stronger pistions, etc, the head will just get a little head work as i have been told they really dont need it for a cam, then i purchase a medium sized cam, vernier gears, etc im going today to my mechanic so he can inspect the car and discuss engine rebuilding place in brownsplains, called peter rose engine reconditioners, will go see him some time soon and get price to get some head work done, will be a slow build , then i can save up and get a flash box and get it to nerang at chip torque to be tuned,
29-09-2009, 10:31 PM | #15 | ||
took car to my mechanic today and its a lifter that has failed, there like 10 dollars each, so next couple of weeks will get all the lifters replaced, and see where i go from there, hopefully i get it done before next friday before rpd dyno night
30-09-2009, 03:59 PM | #16 | |||
30-09-2009, 04:22 PM | #17 | |||
Afterburner + skids =
Seriously though, give the car a service and while you are at it, degrease the underside of the engine and see if you can see any leaks.
30-09-2009, 04:36 PM | #18 | ||
lol i ment i applied for the jobs
nah rather i get some one who knows what they are doing, incase i stuff it up, and the same time i will get the service done while he is at it
