10-10-2009, 07:17 PM | #1 | ||
XR6T 400kw(well one day!)
Hi all...
When my engine is idling there are little bubbles blowing into the coolant bottle. When I increase the revs the bubbles increase. Now I know straight away that the first assumption is a blown head gasket. However the car runs perfect, no coolant loss and no water in the oil. Before i start ripping the head off I would like to know if there is anyother possibility for the bubbles. I did change the bottom radiator hose last week. Could that have anything to do with it? Thanks.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory |
10-10-2009, 08:24 PM | #2 | |||
Flairs - Truckers Delight
10-10-2009, 09:27 PM | #3 | |||
Miami Pilot
JC
10-10-2009, 10:36 PM | #4 | ||
Thanks fellas,
Thats what I was hoping to hear. I will run the car without the radiator cap as you say, and see how I go. Will post back tomorrow. Cheers.
11-10-2009, 12:08 AM | #5 | ||
Yeah, get the car to normal running temp with the expansion tank lid off...if you are nearby it may even "burp" for you
1994 ED 2008 BF XR6 |
11-10-2009, 01:10 AM | #6 | |||
Yep I hope so. Dont have the time to change a head gasket at the moment. To busy with work around the house!!!
07-11-2009, 07:53 PM | #7 | ||
5.0 means business
Thanks So Much for this just had the same problem going to give this a try.
Windsor V8 Enthusiast! Turbo Barra Lover! |
07-11-2009, 11:21 PM | #8 | ||
Thanks for the advice fellas. The bubbles were from the hose I changed.
Quite surprised how long it took for the air to bleed out though. Best thing is - no head gasket! - Phew!
07-11-2009, 11:24 PM | #9 | ||
yep - i knew it would be
