Old 11-11-2009, 09:01 AM   #1
amiers
Default firing order on coils
may be a dumb question but, how do you work out the lead placment on the twin V8 coil packs? of course you take off one lead at a time, however if you were handed the coils and leads how would you work it out?
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2009, 10:52 AM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Wait till I get home and take the engine cover off and post a picky if you like :
Originally Posted by Riksta
Old 11-11-2009, 11:16 AM   #3
5L
[ 5L ]
5L's Avatar
about 95% sure this is right lol, its bloody hot outside and i only turned my car off bout half hour ago. the way ive bunched the leads up on the passenger side its hard to tell where they go to as there crossed over each other.
the sequence on each side of the motor
drivers side starting from front
1 2 3 4
passenger side starting from front
5 6 7 8
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2009, 11:22 AM   #4
RG
Back to Le Frenchy
RG's Avatar
If they are original Motorcraft coils the lead placement is printed on them. Pots 1-4 are drivers side front to back and 5-8 passenger side front to back.
I'll try to chase up the correct coil placement for you.
EDIT: Looks like 5L has sorted it, from memory that looks correct.
Old 11-11-2009, 11:29 AM   #5
5L
[ 5L ]
5L's Avatar
i think i might of stuffed up the picture above,
ill wait for someone else to verify.
maybe i stuffed mine up when changing mine and been driving it since :
Old 11-11-2009, 06:58 PM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
Well hope yours is running ok : mine goes from front drivers side to passenger side
8 2 6 1.. to rear drivers side to passengers 4 7 3 5
.....................................4 7 3 5 .................................................. ..........
.....................................8 2 6 1................................................. .........
factory coils and TG numbered Blue leads
Old 11-11-2009, 07:16 PM   #7
5L
[ 5L ]
5L's Avatar
yeah im fairly sure that is what mine is running whoosha, i only had a quick look.
ill go check to be sure though ahaha.
Old 11-11-2009, 07:28 PM   #8
Whoosha
AU DIE HARD
Whoosha's Avatar
Make for a good flame show out the zorst with that firing order : :
Old 11-11-2009, 07:33 PM   #9
Peuty
Afterburner + skids =
Peuty's Avatar
Here you go chaps
http://fordforums.com.au/vbportal/mo...article&id=308
amiers, don't worry, it isn't that embarrassing
Oo\===/oO
Old 11-11-2009, 07:37 PM   #10
5L
[ 5L ]
5L's Avatar
i dont know how i wrote down the wrong numbers. just checked and mine is right ;)
Old 11-11-2009, 08:08 PM   #11
amiers
Thanks guys. so plug lead #1 goes to the 1st plug on the drivers side at the firewall? my leads are numbered and from the front of the car starting at the drivers side rear(nearest to firewall) its 1,2,3,4 then 5(behind power steer).6.7.8
Old 11-11-2009, 08:26 PM   #12
Whoosha
AU DIE HARD
Whoosha's Avatar
#1 would be the first at the front driver side
Old 11-11-2009, 08:48 PM   #13
Peuty
Peuty's Avatar
As per the above diagram that I posted.
Oo\===/oO
