Old 28-10-2009, 09:05 PM   #31
TheInterceptor
Cruising...
TheInterceptor's Avatar
sorry to be a bit of topic but on the subject of LED's,
Do T10's fit as parkers?????
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2009, 10:11 PM   #32
ronwest
All Bran = Regular Member
I don't see why not.
I just went down the shed and fitted a T5 LED into the parker of a spare headlight I've got.
It was loose but at a pinch I could get it to fit (and stay there) so there should be no problem with a T10.
Old 28-10-2009, 10:19 PM   #33
TheInterceptor
Cruising...
Thanks mate
Old 29-10-2009, 10:22 AM   #34
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Originally Posted by ebv8
i just replaced mine with blue leds and now i can't see the needle so at night i have to guess how fast i'm going so i'm taking them out and replacing them with std lights
I have 10 t5 blue leds forsale now
In the back of your dash cluster the places where you're globes go will be like this (in a bent form, 1 & 6 at the bottom and 3 & 4 at the top - I tried to do that on here but it wouldn't show properly).
1 2 3 4 5 6
To be able to see the needles, in slots 2 & 5 I have put normal globes for enough light to light the needles, and in all the other spots super bright blue LED's (they have 3 LED's per socket). Lights up the dash quite nice.
And for the globes behind the ODO display - go into any Autobarn/Repco etc and quote the part number "Narva 47734", they're about $2 each. I haven't even bothered trying to replace them with LED's.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2009, 06:58 PM   #35
Halfmo Rocks
Bearded Hermit
yes...i have t10 blue LED's as parkers. pain in the **** to fit though.
i have done the LED's in the dash...but they suck...where might i buy real old fashioned glass bulbs from? i know ebay doesn't have them going anywhere
Halfmo Rocks is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2009, 11:01 PM   #36
ronwest
Why do yours suck?
Old 07-11-2009, 06:59 AM   #37
GS608
autobarn, supercheap repco bursons take your pick i suppose.
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2009, 09:29 AM   #38
Halfmo Rocks
Bearded Hermit
Originally Posted by ronwest
Why do yours suck?
they just ain't bright enough, very spotty - directional light...not being able to see the needles has already been mentioned
thanks mate...figured as much - i'll check them out...sucks i can't find em online though
Old 07-11-2009, 10:03 AM   #39
ronwest
The needles are a problem but the spotty effect is overcome by painting the top of the globe white. That tends to diffuse the light. When I was playing around with mine I came a cross some "three-legged" LEDs which you could splay the legs to suit the dark spots. They were much better but better again when I also painted the tips of them.
Mine are plenty bright enough and only one small darker area but the needles really do need sorting out.
I have that marked down at "Job 257" so there's a few jobs to get through first, lol.
Old 07-11-2009, 11:23 AM   #40
ronwest
Just for reference, these are "six-legged" leds. Would prob be better for diffusion than the three-legged that I used.
http://cgi.ebay.com.au/T10-6-LED-Blu...item5ad414d02f
Old 07-11-2009, 11:37 AM   #41
Halfmo Rocks
Bearded Hermit
if they were t5's it might solve my problem...buy they are t10's.
i have tried the 3 legged ones...better than the single...but now by much, socket is too narrow to spread the 3 as wide as u want
in any case...it's just not the same as real glass bulbs
Old 07-11-2009, 12:21 PM   #42
ronwest
Oops, meant to say they are the "type" not necessarily the size.
I guess it's horses for courses. I much prefer the blue to the standard globes.
If I can work the needles out I'll be a happy chappy
edit: I just rem that I spread the "legs" (can we say spread the legs?) with a jewellers driver after I had the globe loosely fitted in the socket.
Old 07-11-2009, 05:46 PM   #43
GS608
As riksta posted earlier i think he may have a solution to the needles.
replace 1,6 & 3,4 with the blue LED and leave 2,5 as the normal globes, i havn't tried it yet but if he says it works a treat then that's fine by me
Old 07-11-2009, 07:16 PM   #44
Halfmo Rocks
Bearded Hermit
the outside isn't the problem...it's the centre...less lights on a greater area mean poor lighting. mine is fine around the edges...but the speedo's lighting sucks
Old 12-11-2009, 11:09 AM   #45
GS608
If we got glow in the dark paint and repainted the needles with it, would that solve the no needle at night problem ;)
Old 12-11-2009, 12:35 PM   #46
ronwest
No, I tried it.
The light needs to come from in front of the needles for that to work.
Old 12-11-2009, 02:12 PM   #47
GS608
bugger, whats the difference between the S1 fairmont and S2? lighting wise, as i've seen pics of HLC's mont with the blue speedo and red needles/other red parts lit up.
Old 12-11-2009, 03:02 PM   #48
ronwest
I read somewhere that S1 needles are clear plastic with an orange coating. The coating could be scraped off leaving the needles clear.
S2's have orange plastic needles (no coating).
I don't know what else Henri did... perhaps he'll see this and comment.
