Pro Street Au Ute
g'day, can someone tell me what the symbol to the left of the odometer in a low s1 is, its a ! With a circle around it and in brackets. Cheers.
Rusticating
Sounds like handbrake.
Territory SYII RWD, BFII RTV tray |
mis read post. DOH.
As said above hand brake. |
#4 | |||
Pro Street Au Ute
#5 | |||
Pro Street Au Ute
Lost Boost Gained Class
sounds like handbrake Switch playing up try and unplug it pull the hand brake boot off and unplug the conecter down there and see if it gose out if so then u need to reco the switch like i did or replace it
2006 BF Fairmont Ghia
2001 AU Falcon |
Afterburner + skids =
![]() Join Date: Dec 2004
Handbrake is a P in brackets isn't it?
#8 | |||
The message you have entered is too short. Please lengthen your message to at least 5 characters. |
![]() Join Date: Jan 2005
The ! in a circle is the brake symbol.
#10 | |||
Pro Street Au Ute
#11 | |||
this year I had major brake booster problems and rear heating of fluid and the only light that appeared to come on and that warned me was the one your talking about....It was the same the "P" one but with a "!" in the circle...I could only assume it too is a brake system problem. The light has never come on again since I had the job repaired....Hope this helps as I cant find anywhere in the car book that same symbol. |
Tickford Equiped
I had that (!) light light up on my dash last week. Went to stop at some traffic lights and the pedal went to the floor. Pumped it up and it stopped ok. Kept coming on and off. Checked the fluid and it was ok, turned out to be a slightly sticking rleft rear calliper causing tremendous heat and boiling the brake fluid, hence no stop.
So yeah, definately the brake system malfunction light. Get it checked ASAP. If its still stopping ok, it may just be a dodgy connection somewhere or as said an airbubble in the system or brake booster on its way out, who knows. But get it checked out, No brakes is not fun let me tell you. Lucky when mine decided not to work i was only crawling along and was at the front of the que at the lights.
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
