Old 20-11-2009, 04:11 PM   #1
Peuty
Afterburner + skids =
Peuty's Avatar
Default Upper & lower control arms
Took the car for a wheel alignment today, they told me that they wouldn't do one as the upper and lower control arm bushes were on their way out. Was quoted $660 to replace them with superpro items. Does this sound right? Who has had to change these bushes before?
Oo\===/oO
Old 20-11-2009, 04:24 PM   #2
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
Bushes themselves are about $260 from Fulcrum. We can (probably) do them ourselves - I certainly hope so, given that I'm doing the same thing to my Falcon on Sunday...
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2009, 04:24 PM   #3
BillC
I have done the upper control arm bushes and they are quite easy. Have not done lower control arm bushes.
Upper ones take about an hour each side once you know what you are doing and its quite an easy job. I got rubber bushes from Pedders but I would not recommend them as they only lasted abot 30,000 Ks
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2009, 04:30 PM   #4
Peuty
Peuty's Avatar
Mmm that was going to be my next question Nick, how bad are yours? You doing lowers as well?
Thanks BillC, was wondering if the rubber equiv would the the go, but for 30K worth of driving, polyurethane seems the smarter choice.
Oo\===/oO
Old 20-11-2009, 04:34 PM   #5
GreenMachine
Mopar/No Car
I'm going to do all the front end rubbers. I've got a death-rattle in the front that's either a ball-joint or a broken swaybar link or something. I'll do everything while the front end is off.
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
Old 20-11-2009, 04:41 PM   #6
Peuty
Peuty's Avatar
I'd come give you a hand, but alas, I am working all weekend...fail.
Oo\===/oO
Old 20-11-2009, 06:16 PM   #7
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
To do the UCA bushes shouldn't take more than half hour. You've only got 2 17 MM nuts and bolts per side to remove them from the bushes. The old ones will fall out and new ones will go in easily. Plenty of grease and bingo.
Worst case scenario to remove the UCA, is to undo the top ball joint. 1 18MM nut and a hammer, then attack the nuts and bolts I've mentioned about
Old 21-11-2009, 03:12 AM   #8
AuV8Fairlane
Fast Lanes Inc.
Hey guys, was just talking about this in the S1 Fairlane Suspension thread http://www.fordforums.com.au/showthread.php?t=11279794 yesterday. I did the entire suspension on my Fairlane not too long ago. As Svo Supporter says the upper control arms are quite easy. To do the job properly undo the 18mm nut on the upper ball joint then undo the 2 17mm bolts and nuts holding the upper arm in. Now you should have the arm out. If the old rubber bush is still in one piece not coming out easily a good way to get it out is to find a bolt (not the one's from the car!) that fits in the steel sleeve inside the bush and hammer it through taking care not to hit the upper arm. This will push the bush out easily. Once thats out you'll more than likely find bits of rubber still stuck inside the arm tube that held the bush. Give it a good clean and if you get superpro or nolathane you'll find the new bush comes in 2 halves and you just slide then in from each end. With nolathane you only grease inside the new bushes where the steel inner tube slides in and the end faces which meet the arm retainer on the car, then push in the steel inner tube and put the arm back in the car.
Now the lower control arms are a different story there are 2 bushes here, the inner front and inner rear. You cannot get these out unless you a) have a fairly large press or b) soak them in say wd40 and bash them to bits even then its a hard task as the bushes have a steel outer shell that has the bush bonded to it. This outer shell is the problem as it is a really tight (interference) fit not to mention the added rust. Ford apparently use use a press with a special holding jig made up on these. Once out clean inside the tube on the lower arm and press in the new bush. You will need a press and adapter (steel tube wide enough to sit on the steel lip of the new bush) to do this or you will mash your new bush. Also keep in mind the inner front (bigger) one has to be lined up before being pressed in as it has a offset centre.
Sorry about the long post but i hope this helps. Matt.
AU V8 Fairlane, Extractors, Magnaflow Cats, Twin 2.5" Custom Exhaust, BA Brakes, Lowered, Koni Adjustables, Nolathane, MSD Ignition, CAI, EL GT Momo Steering wheel.
AuV8Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2009, 07:16 AM   #9
sly
Sly like a G6
sly's Avatar
I may be wrong here but I have a vague memory that to get the LCA's out you have to back off the subframe nuts a fair way to lower the subframe for clearance to remove the LCA's.
I got some 300,000 k's from the original bushes and only changed them because I had the suspension off to fit BA brakes (to my Series 1). Ball joints and swaybar D bushes OTOH are almost consumables, they give out so frequently. Best to change these as well while it's in pieces.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2009, 07:41 AM   #10
rag top
rag top's Avatar
Peuty, price the full front end kit;
http://cgi.ebay.com.au/Ford-Falcon-A...item414a6e8b93
If the upper control arm bushes are shagged, what other bushes also need replacing??
