Old 23-11-2009, 06:12 PM   #1
benny_mac
benny_mac's Avatar
Default Which radiator???
Hey all,
I'm just wondering if anyone knows which radiator i should use. I have an EA s1, using an AU engine and i'm not quite sure which radiator to use. Because the ef and up have the bigger water pump inlets and i dont really want to cut and shut the hose, the El radiators have the right size outlet but have the header tank inlet pointing towards the engine where as the EA needs it pointing to the side. Now i think the V8 radiator has the header tank inlet on the side but i don't know if the radiator outlet is the same as the au water pump inlet.........
Does any one know?
Any help would be greatly appreciated.
Benny Mac
New Project: 1980 MK2 Escort Panel Van, 2lt, auto
Soon to be painted running a 4.0ltr v6
See the build here
http://www.fordforums.com.au/showthread.php?t=11388068
You Have Freedom of Speech Just Choose to Remain Silent
benny_mac is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2009, 06:14 PM   #2
benny_mac
benny_mac's Avatar
Woops, can someone please move this to Tech area.
See the build here
Old 23-11-2009, 06:22 PM   #3
mickyyyy
Any good radiator joint will be able to replace the tank to suit ur requirements and i suggest u use an ADRAD unit, they have a high performance unit which the tubes are bigger than the factory.
Factory is 10mm 2 row and high performance is 12.7 2 row and i have it and it works great.
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
